Tire Bead..........???
Old Apr 6, 2007 | 05:59 PM
double d6's Avatar
Default Tire Bead..........???
Anyone here ever have any trouble trying to get a front tire's bead to sit correctly?
I've done this before and just got done doing the back tire flawlessly, but the new kenda front tire is not cooperating. The bead looks good except for a 6 inch area where it is recessed into the tire and wont come out. I've filled tire up to about 35psi and it wont come up, should I pump more air?
I've taken it apart two times now this morning and no good.
Maybe the tire itself is just bad!!!
Well, if anyone has any ideas....I'm all ears.
Therear Trakmaster looks good with the new chain and sprocket!!!
Dave
Old Apr 6, 2007 | 06:09 PM
a16tony's Avatar
Default RE: Tire Bead..........???
I always put Armoral on the bead, or you can try a water/dish soap solution. Then pump it up too 50lb to seat the bead, then the recommened pressure.
Old Apr 6, 2007 | 06:14 PM
What Tony said. Windex works good too. Deflate it all the way, then squirt it around the rim/tire area to lube it up, and crank it back up to around 50 or so and it should seat into place. Then air it back down.
Old Apr 6, 2007 | 06:19 PM
double d6's Avatar
Yeah, I figured I should pump it up more.............gonna do that after I finish putting the tire back on.
Man, what a workout it is to change a tire 4 times manually in one morning!!!!!
These rim locks sure don't make things any easier[:@][:@]!!!
Thanks guys-
Dave
P.S.---I've heard some good and really bad reviews on these trakmasters...........hope I find out how GOOD they are.
Old Apr 6, 2007 | 07:20 PM
I really like them, they are great for off-road, but do not push them on-road.
Old Apr 6, 2007 | 07:49 PM
lcpl0331's Avatar
+1 on that. dirt... great road..... not so much. don't go hot into a corner on the road. these things slide real easy. it's actually fun but if your not prepared for it it'll scare the crap outta you.
Old Apr 6, 2007 | 08:00 PM
ol guy's Avatar
Put some soapy water around the bead add about 30 pounds of air then take a hard plastic or rubbermallet and pound the side of the tire. Hit it at an angle away from the rim and it should pop the bead out.
Old Apr 6, 2007 | 08:06 PM
double d6's Avatar
ORIGINAL: ol guy
Hey man..LOL......that's exactly what I just did..........but mostly out of frustration and now I hear you say it's OK......WOW that takes a load off.
Little more pounding to go and she should be set all nice----Thanks guys
I always find my answers here.
By the way.....you guys running the kenda's,,,,How are the fronts? I hear negatives, but wanna hear what you guys think?
Dave
Old Apr 7, 2007 | 02:04 AM
TeamKLX250's Avatar
I only have the rear Kenda, @ around 5,500 km my stock 603 is still going strong
Old Apr 7, 2007 | 03:07 PM
ReaperFox's Avatar
I recommend the same methods that are voiced here. Some soapy water along the edge of the rim and then once the tire is on and inflated then use a rubber mallet and work your way with firm, moderate taps ( avoiding the rim ) along the sidewall and it will help the bead work its way in place.
So far I've had to do it with every Kenda I've ever ran, front and rear alike. I just write it off to Kenda making the tires with some tight tolerances. Makes for a nice snug fit once its worked into place though.., a rubber mallet is the only thing I've found that works though, don't want to use a hammer or anything to solid or else you'll risk doing damage to the tire or worse yet, the rim.
PSUdude85
Jan 15, 2011 04:48 PM
86gpz1000
Apr 17, 2010 05:06 PM
fireroad
Jul 13, 2007 09:16 AM
scat
Jun 12, 2007 03:11 PM
kali_ninja500
Ninja 500R
14
Feb 10, 2007 02:13 AM
