Timing/Cam Chain Clacking
Well If your KLX needs those parts at such low mileage then It was either hammered beyond insanity or these KLX's are not the Tanks I thought they were. I really expect a chain & guides to last 10's of thousands of miles even if ridden hard. Same with valve seals. I do agree it is probably time to pull it apart & see what's going on. I'm gonna guess the noise is higher up in the engine, maybe cam or valves.
Before anyone asks this, its not valve clearance. Trust me, I've checked the valves three time since I owned it. And its always remains dead center on. Along with Cam timing before.
Got my parts today. Unfortunely, I forgot to order a head gasket as well. So this weekend, I'll be working on the KLX cam chain. Lots of photos to come afterwards.
Cam Chain, Part # 92057-1416, $79.88
Flywheel holder tool, Part # 57001-1313, $234.17 (I got it at $205)
Valve spring compressor tool w/ spring adapter, Tool Part # 57001-241 / Adapter Part # 57001-1202 ,Tool $98.39 / Adapter $23.15. The Valve spring compressor comes with a spring adapter but its the wrong one and is meant for larger springs. So you need to order the correct adapter with it.
No kidding. I think me heart stopped for a second when I found that out. It will be still usefully to keep. I have 3 motorcycles, well I own 1 of them (06' KLX250s, 85' Honda NightHawk 650cc, 07' Yamaha Virago 250cc).
The problem has been solved. It took 7 hours of work, but after all said and done. I love how it sounds now. No more wrench banging monkey inside the engine. Nice and smooth at idle. Pulls all the way through without a clank. The KLX is actually an easy engine to work on. Just gotta have the correct tools and the repair manual to help along.
A few good tips and tools:
New gaskets: They rip easy and may leak after you reinstall everything
Hi-Temp RTV Silcone: If a leak if found, use this to fix it. My water pump leaked afterwards, this fixed it.
Torque wrenches: Highly recommended, will make sure that aluminum doesn't strip out.
Lubicant Spray: Any kind works, use it for every bolt that goes back in. Most of the bolts that I pulled started corroding.
And yes, lots of pictures.
Photo of the KLX before I begin work
Plastics and seat removed.
Draining fuel
Fuel tank removed
Clutch cover removed
Left engine cover removed. Fly wheel holder tool in use.
Right engine side cover removed.
Bottom of Cam Chain
Clutch plate removed
Engine top-end and cam shafts
Cam chain removed after removing cams and water pump drive.
Cam chain lenghts between old (top) and new (bottom)
Clutch pressure plates.
Final results of all the hard work.
I'm glad the clanking is stopped. KLX runs great now and the valve clearance is still dead within spec. Hope this helps some. If needed, I can scan the pages of the repair manual for that need it.
Draining fuel
Fuel tank removed
Bottom of Cam Chain
That's great man!! Glad you got it fixed. Was the problem that the chain had stretched, or the guides were worn, or both? I just had to replace the tensioner on my klr. It got rid of the clatter but I still have a jingle sound at 7k. We need to get together and ride sometime.
Next project: Fix the riding lawn mower clutch and replace belts. Oh the joy of never ending fixes.
