Tearing down the bike, anything hidden I need to know?
Old Sep 6, 2009 | 04:23 PM
cliffsta's Avatar
Default Tearing down the bike, anything hidden I need to know?
Well its supposed to rain today / tomorrow, so I can't ride BUt I have the itch to take everything off of it that I can, clean it, service it, lube it, whatever. Other than the obvious stuff like plastics and gas tank and airbox, anything else I can take off and lube or clean? I'm thinking about the swingarm, since I have so much time.... never had it off the bike... Any suggestions?
Old Sep 6, 2009 | 04:54 PM
CousinLarry's Avatar
I would grease all bearings.. Swingarm, wheels, stearing column (or what is it called on a bike?! haa) Lube your chain and check it's slack, oil change, coolant flush, clean/oil air filter...
That's probably a good start
Old Sep 6, 2009 | 06:15 PM
cliffsta's Avatar
Changed the oil Friday night... hmm coolant flush is a good idea... Also gonna do the emissions ellimination thingie... you know, the hoses off the airbox that go to the engine and the exhaust or whatever ya clal it...
Old Sep 7, 2009 | 01:25 AM
WestOzKLX's Avatar
Y mod for the carb' breathers. MTB tube or old wetsuit sleeve, over the rear shock if you have it out. Keeps it cleaner. Just leave a hole up top and down below for air to circulate and water to drain.
Old Sep 7, 2009 | 02:15 AM
LearjetMinako's Avatar
If you are going to tear down the KLX. Remember to get your self a tub of moly greese to re-lube everything.
Old Sep 7, 2009 | 03:04 AM
Brewster's Avatar
Put some anti-seize on the bolts that go into the tank.
Pull the front axle also and grease it up.
Get one of the cable lubricators and use it on the clutch and throttle cables.
Ride on
Brewster
Old Sep 7, 2009 | 06:33 PM
slippery750's Avatar
Blue loc-tite on most bolts on reassembly.
Spacemanspiff
Mar 28, 2008 11:41 PM
jdejong7640
22
Jun 22, 2007 09:50 PM
srobak
Dec 7, 2006 09:29 PM
BIG V
Aug 7, 2006 06:02 AM
cruzin
Jul 28, 2005 07:18 AM
