Switching to synthetic?
Old Aug 13, 2008 | 11:58 PM
je2000's Avatar
Default Switching to synthetic?
I'm getting ready to do my first oil change, still need a torque wrench, filter and oil...hehe...But I was wondering what I needed to do besides drain all the previous oil if I wanted to switch to synthetic. Do I need to flush everything completely out somehow?
Old Aug 13, 2008 | 11:59 PM
barthel75's Avatar
no you dont but i would not run full synthetic its no a high performance bike run a semi blend like motul 5100
Old Aug 14, 2008 | 12:46 AM
klx250s_rider's Avatar
I'll probably take some hits for this but make sure you're engine has been "broken-in" before switching to synthetic oil. What's "broken-in"? Some will say several hundred miles, some say 1500 miles, I waited until it had 800 miles before the switch.
Let the dino/syn oil controversy begin!!!
Old Aug 14, 2008 | 12:54 AM
je2000's Avatar
Great! Now to order the torque wrench...
Old Aug 14, 2008 | 12:57 AM
je2000's Avatar
I got it at 1000 miles and it just had it's first service. Amazingly the manual says 7500 miles before next ANYTHING...All I know is that little oil window is loooow....
Old Aug 14, 2008 | 12:59 AM
klrjr's Avatar
Default +1
+1 wait until motor is broken in before the switch. I also wouldn't run full synthetic if an engine already had a lot of miles. Start it at the right time and then stay with it, IMHO
Old Aug 14, 2008 | 01:00 AM
If it was low, I would def. do an oil change,, but mine has 1200 and im still waitin a bit, before I go syn.. I think im goin to run with the Motul...
Old Aug 14, 2008 | 01:10 AM
je2000's Avatar
It's been 100 degrees almost every day here, is the 10w-40 motul 5100 OK? Shouldn't get any higher than that, except for a freak heatwave.
Old Aug 14, 2008 | 02:04 AM
TUCAZ520's Avatar
get a small tube of grease. youll need a small dab on the end of the spring to hold it in place when you put the new filter in.
Old Aug 14, 2008 | 11:23 AM
barthel75's Avatar
15w50 in hotter weather 10w40 in colder weather
