suspension problems
Old Jan 15, 2013 | 06:25 AM
tonsinclair's Avatar
Default suspension problems
I have ridden bikes before but this is the first one I've owned. Its a 2006 klx 250. Today I was riding and while going through an intersection and hitting a small bump I heard a noise like something was rubbing up against the tire or it bottomed out. After that any little bump I hit makes the same noise with a lil vibration on the back tire. I just had my rear tire taken off to have the inner tube replaced about 4 days ago. Could it be that they did something to mess up my suspension, or does it just need a little readjustment, or did I break something? Nothing seemed to be broken when I checked it out. hope someone can help, I wanna get back to riding asap.
Old Jan 15, 2013 | 01:47 PM
cmott426's Avatar
Check your pivot (suspension components) and wheel bearings.
Old Jan 15, 2013 | 02:06 PM
Could be just about anything. chain guard, shock, tire on wheel wrong, chain, sprockets, brakes.
Old Jan 15, 2013 | 02:24 PM
I'd be concerned about the flat fix resulting in something not reinstalled properly or not adjusted properly. Chain tension comes to mind as a likely suspect.
Old Jan 15, 2013 | 04:13 PM
Spacers installed on wrong sides?
Old Jan 15, 2013 | 04:39 PM
lets go with option D. All of the above. lol
Old Jan 15, 2013 | 04:46 PM
durielk's Avatar
If your not a mechanic, take it back to where you had the tire done and have them take a look at it. It sounds like they may not have had the 'A' team on it.
Old Jan 15, 2013 | 05:02 PM
Didn't have the A-team on it? I can't believe you'd suggest such a thing. I'm relatively sure the shop foreman himself did the work on that flat.
Old Jan 15, 2013 | 05:41 PM
"I pity the fool who allows others to work on their bikes" Oh and welcome to the forums.
Old Jan 15, 2013 | 05:56 PM
I'm taking it back to them....Thanx
