Suspension mods for heavy guys.
239.00 for all installed, I had to pull the shock and the front forks and reinstall but that only took about a hour and a half of my time. He help me with the sag adjustment on the rear and from there on i was on my own with getting compression and rebound adjustments.
Hey Duvallgold he just up the road from you. He is located on the woodinville duvall rd just past cottage lake. John is a good guy I highly rec. him.
I thought I remembered seeing one of your posts that you had taken it all apart. I'll try to ride over there in the next week or two and talk to them. Did you need an appointment or is it more of a retail setup there?
On another note, I finally found the road that goes through from Stossel creek to Sultan. There's one main gate in the way but it was open tonight so I was able to ride it. You could duck your bike under the gate if it's closed though. Then if any DNR guys try to give you a hard time about being out there, you can just say you came from whichever side of the gate you're on. It's a ncie little shortcut through to Sultan and alot more fun than 203. Are you still going out on the 9th? I've been looking at some maps. looks like most of the really fun stuff is on the other side of the passes. I'm going to do a little more exploring up stossel this weekend.
John works out of his Garage so it is best to give him a call. He's Monday thru Friday, He takes sat and sunday off so he can ride
Yep still on for the 9th, I also got the 5th off so i might head out for awhile also.
