Suspension - HELP
Old Oct 16, 2011 | 03:16 PM
David R's Avatar
I put new valves in my front forks. Huge difference. Suspension was "compliant" if that is a word. Rear shock was OK for me.
This was on an SF which had stiffer springs front and back.
David
Old Oct 17, 2011 | 12:31 AM
Originally Posted by durielk
In lieu of re-valving, has anyone tried using thicker fork oil or changing the oil volume? I think my 07 could use a little firming up. It is basically stock & I am 170#, so I think the springs are very close.
go find some of zombywoof's posts on the subject. He did.
Old Oct 17, 2011 | 12:45 AM
The main problem with the fork is that the stock compression piston won't flow enough oil for either hard fast hits or several successive hits. Going to heavier oil with the stock valving will only aggravate this problem. I think the "firming up" you feel you need is still in the spring department. I've heard some suggest the OEM front springs are more suited to a 140-150 pound rider. At 170 I'd think some .42 springs would be more suitable than the .38's that are stock. Heavier oil is not the solution IMO. Your rebound is going to slow down a good deal with thicker oil, and it's right at the limit of being too slow already IMO.
Old Oct 17, 2011 | 04:35 AM
Blackheart58's Avatar
Listen to TNC...
Old Oct 17, 2011 | 11:08 PM
redpillar's Avatar
Yes listen to Blackheart
Old Oct 17, 2011 | 11:09 PM
redpillar's Avatar
If you doubt Blackheart, then listen to TNC
Old Oct 17, 2011 | 11:47 PM
Just stand up on the bumps, it works every time. LOL
Old Oct 18, 2011 | 05:14 AM
listen to redpillar!
Old Oct 18, 2011 | 05:27 AM
wynn711's Avatar
Listen to deej. If it ain't broke, don't fix it!
Old Oct 18, 2011 | 11:05 AM
ns503's Avatar
So then how bout thinner oil?
