Surge at 6500 rpm at highway speed
Old 12-21-2010, 05:52 PM
seth6025's Avatar
The needle in mine is the dynojet one, guess I should add that to my signature
Old 12-21-2010, 10:32 PM
kansas-klx's Avatar
Add another shim the same (.060"/1.52 mm.) I've used a 1.5mm on the stock needle and the result is good.
Another shim it shall be.
Even with the baffle drilled, will stock exhaust offer any complications on top of this? As more fuel is added to the mix I don't want to run into back pressure issues...
Old 12-21-2010, 11:13 PM
WestOzKLX's Avatar
AUS bikes come stock with a #132 main jet. Mine ran fine with the stock pipe. I can't foresee any problems as your main is still smaller than that (#125.)
Old 12-22-2010, 12:14 AM
David R's Avatar
Thumbs up
Good to know. MY usa model came with 118 main jet. I kept going up till I got up to 132. It seems about right now.
David
Old 12-22-2010, 03:06 AM
kansas-klx's Avatar
Default Added another shim to needle for .060" as suggested
From beginning of removal of side panels to putting the kickstand down after a short test ride in the neighborhood, the modification of my modification took 2.5 hr.
Didn't take it out on the highway but in the neighborhood tonight it seemed a little more peppy when I'd pop the throttle than before. Never exceeded 25mph, though. Tomorrow after work I will likely take it out for testing at much faster speeds. I'll report results afterwards.
Thanks to everyone for your posts, so far.
Old 12-22-2010, 03:10 AM
wildcard's Avatar
Just a bit of friendly advice, when talking about possible jetting/carb issues its better to state what throttle position the problem lies at instead of engine rpm.
Carb tuning is dictated by throttle opening (by knowing which fuel circuit is in use at the time) not rpm.
Old 12-22-2010, 03:39 AM
kansas-klx's Avatar
The original problem was less than 3/4 throttle.
For a while I've had a piece of tape on my right handlebar with 1/8 increments all the way from idle to full throttle so that I could tell what was happening and when. Sorry I neglected to mention that. Thanks for bringing it up.
Old 12-23-2010, 01:47 AM
kansas-klx's Avatar
Default Fixed it!!
Adding the extra shim to the stock needle to create .060" total lift fixed the problem. Now at further throttle opening it seems the surge may have moved to a higher point. At least its now out of my projected normal highway commuting speed range.
The new "maybe surge" is likely due to the main jet being a #125. Temp today during ride was 32*F and very low humidity meaning denser air. As temp and humidity will increase with the onset of warmer weather and yield richer A/F mixtures, I may wait a while to work with this issue. It may turn out to be a non issue. I have a #128 jet just in case, though...
Once again, thanks for everyone's replies.
Old 12-23-2010, 06:10 AM
What's the rpm and throttle position now when it surges?
Old 12-23-2010, 11:58 AM
kansas-klx's Avatar
Looks like around 7K at or just above 3/4 throttle...
Quick Reply: Surge at 6500 rpm at highway speed
