starting problems
Old Mar 14, 2008 | 03:48 AM
nosneb69's Avatar
Default starting problems
whats up fellas, so I got back (last sunday) from riding andput the bike up. I have not washed it and the dam thing wont fire up!!! I have bypassed the kickstand switch, bypassed the clutch switch. I have removed the plug and held it up against the frame whilst turning the engine over - no spark.....? I have check every fuse and connection - no spark!!!!
The only electrical MOD the bike has is LED turn signals and the plate holder removed....
Does anyone have an idea.....?
many thanks
Old Mar 14, 2008 | 04:10 AM
justin's Avatar
Default RE: starting problems
Cleaned it up and keep asking around on the web. Wish I could help..
Old Mar 14, 2008 | 09:44 AM
stupid questions but have to ask.... is the kill switch still pushed in?
Old Mar 14, 2008 | 02:00 PM
nosneb69's Avatar
morning, well the kill switch is out. If pushed in then nothing works, does not even turn over. The bike turinging over but without a spark, I have never hurd of a coil buring out...... klx '07 with 850 miles on it......strange I tell ya!
Old Mar 14, 2008 | 04:01 PM
nosneb69's Avatar
So still going at it trying to find the problem,are there any hidden fuses under the tank...? I have changed the 20amp main fuse, checked all connections, checked the other two tube fuses ( all under the seat) ....... anybody have a clue why the B*745&* won't fire...?
Old Mar 14, 2008 | 04:28 PM
bryantjt's Avatar
Did you change the sparkplug, or check if there was crud in the sparkplug boot? Check that the sparkplug wire is firmly connected/bolted as well.
Old Mar 14, 2008 | 04:32 PM
jfa686's Avatar
I had to have my whole wiring harness replaced for the same type of issue..the shop could not figure it out
Old Mar 14, 2008 | 04:53 PM
mudjunkie's Avatar
as bryantjt said, make sure the plug is good, then I'd checkall of the connectors in the CDI and coil area and plug wires up to the plug itself to see if any came unplugged or became corroded. Good luck and let us know what u find.
Old Mar 14, 2008 | 09:12 PM
nosneb69's Avatar
the update on the very expensive paper weight so far that it still does not run!!!! I have checked every connection, I even got the multi meter out and found that there is no power going to the coil.... so now where do I look..?
Unfortunately I am in Honduras where a Kawi dealer is no where to be found, but that does not seem to matter by the sounds of things as they are usless anyway.......
The plug is as clean as the day it was installed and there is no crud around the cable.......or connection..!
ahhh...now I am lost?
Old Mar 14, 2008 | 11:13 PM
gerrynolan's Avatar
If all the wires are connected and tight then it could be a beat CDI. Or some other component in the ignition system
