Spring Rate Calculator
Old Mar 12, 2010 | 12:33 PM
Einfahrt's Avatar
Default Spring Rate Calculator
I just discovered through another post that I can upload files to forums. So, attached is a simple and helpful spring rate calculator I made a while back and use to determine the spring rate of shock springs and some fork springs using only calipers an the calculator. You'll need calipers to make this practical, as the wire diameter especially is quite sensitive to error, being to the 4th power in the equation.
I've done some experimentation to tweak the equation to more closely match the spring rates of parts with provided spring constants.
Anyway, it's yours to use as you please. Open to suggestions on how to improve it.
For those of you in metric countries, I provide a conversion to kg/mm in the output. Sorry, we still use pounds and inches in my little corner of the world. You can alter the formulas in spreadsheet to flip the units.
Old Mar 13, 2010 | 07:42 PM
ryathis's Avatar
Very nice thank you for posting!
miniman
Apr 9, 2015 05:14 PM
rlj
Jan 15, 2015 09:20 PM
drm
Jun 5, 2013 02:07 AM
Skeets
Ninja 250R
21
Oct 16, 2007 04:59 PM
heffay
Apr 22, 2006 06:10 AM
