Spokes- how often to check?
Old Jun 21, 2006 | 09:17 PM
incabiker's Avatar
Default Spokes- how often to check?
Just something I was thinking about, how often should we get our spokes checked to make sure they have correct tension in them?? Has anyone done this yet?
Old Jun 22, 2006 | 01:37 AM
bryantjt's Avatar
Default RE: Spokes- how often to check?
Per the dealer I checked them at 20 miles. His recommendation, while not exact is to tap them with a pencil or something light and hard. They should make a crisp musical note, not a dull thunk. It's definitely far from perfect but its better than nothing. Every few hundred miles is probably reasonable.
Old Jun 22, 2006 | 01:40 AM
Joshua is exactly right. I use a 10 mm wrench and pretend I'm playing a harp. Go all the way around both sides. They are not all going to sound exactly the same octave, but you will know if you have a dead one that is deeper in sound.
Old Jun 22, 2006 | 02:30 AM
954ken's Avatar
Make sure you have a dial indicator to check run out when you ajust them, if you dont you could end up with a real mess.
Old Jun 22, 2006 | 04:23 AM
incabiker's Avatar
How do you guys know that to even set them too. On the mountain bike I used to have you would have to set them to a certain tension, if not the the wheel would be bent every which way.
crf230
May 15, 2009 04:26 PM
Davebert
Apr 19, 2008 01:22 AM
Davebert
Mar 17, 2008 11:33 PM
Davebert
Feb 27, 2008 06:07 PM
incabiker
Jul 2, 2007 01:00 AM
