So I did the mods....
Old Oct 19, 2006 | 04:45 PM
IchWarriorMkII's Avatar
Default So I did the mods....
Ands its slobbering rich.
140 Main
125 Secondary
No shim on the needle
1.5 turns on the fuel screw
Im going to drop the 135 back in, maybe turn the fuel screw back in .5 turns. It would barely run with the the boot off the carb it was so rich...
I guess it wasnt so bad after all? Anyways, my bike is torn apart. Weee.
Old Oct 19, 2006 | 10:26 PM
Firedude's Avatar
Default RE: So I did the mods....
and you will need to adjust for altitude a bit
Old Oct 20, 2006 | 12:07 AM
Waxface's Avatar
did you take your airbox lid off?
Old Oct 20, 2006 | 12:32 AM
Correction:
#40 ( Why I got 140 in my head, Im not sure. I was cold and tired [&:]) Pilot.
125 Main
Needle was not shimmed (This will richen the mixture, correct?) I have the shim now, but not installed.
The fuel screw was only out 1.5 turns because Im at 6,000 feet.
The lid was off, the boot to the carb was off. My put together plan is to have a KDX200 snorkel.
Im going to go back to a 35 pilot, Im debating on shimming the needle as well... it would be the easiest to remove if its still rich.
Old Oct 20, 2006 | 01:01 AM
Kawi Wawi's Avatar
More shim on the needle = more rich...
Old Oct 20, 2006 | 07:04 AM
In short, Im an idiot. When I pulled the top end apart, I fubar'd the thing. Once my cousin and I figured things out and we borrowed some pics from the HMF forum, the solution became clear to us. The needle was starting down, so it was hard to start (fuel starved) and would then get pulled up, and only run at high rpm ( Getting WAY too rich in the low end). Some deductive reasoning found our little problem out.
By now I had the carb apart out of the bike 4 times, and was back to stock settings. It started and ran great. Yay. We then installed all the mods, and assembled the bike. It runs great.
The low end zip is much improved, it sounds a LOT better, the top end was the same, maybe a little worse? I think the HMF pipe should put the same zip in the low end back in the high end. It starts great, even in the cold weather ( My hands were frackin cold after a few test runs). The following mods we done:
#40 Jet
#125 Jet
Shimmed the needle (With a stolen washer )
Fuel screw out 1.5 turns from bottom (Was out .75 turns stock)
KDX200 Snorkel
Waiting on the HMF slip on pipe to come in.
I can now wheelie in the first gear with a perfect combination of throttle and body english. Im curious how much better the pipe will improve the top end to wheelie more consistently. At 115 pounds nekkid... Im an extremely light rider, Im surprised it didnt wheelie better, but then again its around freezing temps outside... so I wasnt interesting in exploring that aspect.
Thanks to everyone for the ideas, inspiration, answers, Im pretty happy with my bike right now. I really like how it sounds, even with the stock exhaust
Old Oct 20, 2006 | 12:52 PM
115 lbs? how tall are you? i got 100 lbs on you.... im 6'1" 220... damn....
Old Oct 20, 2006 | 04:39 PM
5' 7'
Yea, I everyone has 100 lbs on me almost[&:]
Old Oct 20, 2006 | 06:42 PM
Ginsu4u's Avatar
How bout this, I'm 6'1" and 140lbs. Like an extra tall stick figure.
