Smaller rear sprocket?
Old Apr 17, 2008 | 02:14 AM
QuiteThumper's Avatar
Default Smaller rear sprocket?
I would like a 39 or 40 tooth rear sprocket for road use. Does anybody know where I could get one?
Old Apr 17, 2008 | 04:24 AM
jsac's Avatar
Default RE: Smaller rear sprocket?
wow, smaller sprocket? stock sprocket is undersized for the stock horsepower as it is... you do alot of downhill riding?
Old Apr 17, 2008 | 04:31 AM
You might just try a 15 tooth on the front. Two reasons. One, its cheaper to try out to see if you will like it, and two its cheaper if you don't like it.
Old Apr 17, 2008 | 02:38 PM
egrant's Avatar
+1 on the 15 tooth. Just put one on my klx yesterday. Now it's set up as 15/42. It cruises in 6th gear at 65 mph (GPS) at 6K rpms. When fighting a headwind 5th gear keeps it comfortably at 60 mph at about 6.5K rpms. Cost was less then 10$ and is easier to install.
Old Apr 17, 2008 | 02:42 PM
egrant's Avatar
ORIGINAL: jsac
With a small windshield the 250 is just fine with 15/42 for street use. Don't think I'd go with that gearing if I was using it most of the time in the dirt though.
Old Apr 17, 2008 | 03:16 PM
I am currently running 15/42 and with the (Bill Blue) Big Bore 330 and pumper carb, it still easily pulls wheelies in first and second. I bought a set of used wheels off of e-bay that I put street tires on and would like to run a smaller rear sprocket on those wheels. The stock chain is set to 1 1/2 on the "snails" running 15/42 so, I would think 14/39 or 15/40 would work fine with the stock chain... making wheel swaps simple.
What other bike has the same rear sprocket?
Old Apr 17, 2008 | 04:05 PM
big lou's Avatar
how is the take off from a light slugish or ok with the 15/42s
Old Apr 17, 2008 | 09:28 PM
egrant's Avatar
ORIGINAL: big lou
I give it a few more revs when starting out but it handles it just fine. I did kill the engine on the first ride with the 15 tooth but I'd forgotten to shift from 2nd into 1st. 2nd gear is not too good from a stop.
DOUBLE
Jun 15, 2010 02:15 AM
RDHJ
Aug 28, 2009 11:39 AM
MK1gti20v
Jan 10, 2007 07:29 PM
a zx6r4u
Nov 5, 2006 06:33 AM
deej
Nov 2, 2006 04:11 PM
