Sloppy kickstand problem
Old Sep 4, 2013 | 12:44 PM
Matthewboerner's Avatar
Default Sloppy kickstand problem
I was doing some maintenance on my 09 (I'm the 2nd owner) and the kickstand has a lot of movement in it so I was investigating what was going on. Well there seems to be a washered bushing in the frame portion of the assembly that shims the bold diameter as well as the width of the kickstands forked end. The bushing is ruined and causing the movement. Problem is, there isn't a part number that I can figure out on that part. Does anyone else have this part on their bike? And help or advise would be appreciated. And I hope I described all that clear enough. Thanks --Matt
Old Sep 4, 2013 | 01:53 PM
I have an '06, and I've never noticed a bushing in the kickstand bolt hole. I don't see one in the parts fiche for the '09 model either. Are you sure there is one?
Old Sep 4, 2013 | 02:23 PM
RockabillSlapMatt's Avatar
Take a picture and ill look at my bike ('10) later this afternoon
Old Sep 4, 2013 | 04:14 PM
ahnh666's Avatar
i have a lot of spare parts...take a picture of what you need...i have a feeling i have it....i have second set of the complete kickstand assembly including the switch and hardware....(minus the kickstand which will be shipped to wildcard)
Old Sep 5, 2013 | 02:09 AM
Here is a photo of it next to a quarter for scale purposes. It's obviously thinner and wolowed out. But any help would be great!
Ps no rush cuz my throttle pull cable snapped on my way home today grr
Old Sep 9, 2013 | 03:00 AM
turnsleft's Avatar
10MM bolt with 12MM shoulder is what you need. Your plastic part was just a quick fix looks like to me. This came out of my 09.
Old Sep 9, 2013 | 03:25 AM
That's pretty much what the '06 looks like too. I'm thinking someone lost the shouldered bolt and perhaps replaced it with that bushing setup.
Old Sep 9, 2013 | 12:16 PM
I have the correct sized shouldered bolt and such but maybe it's worn down and that's where that bushing came in? Oh and the bushing is metal, not plastic. Thanks for the pics and input guys, hopefully I can measure up my hardwear and see what's causing the slop.
Old Sep 9, 2013 | 01:14 PM
ol'klx-er's Avatar
From day one mine had "slop". I think it's designed that way. It let's the angle of the bike be adjusted a bit while it's on the stand.
Old Sep 10, 2013 | 04:08 AM
turnsleft's Avatar
Oops
If you know someone with a lathe it would be ez to make a sleeve.
