Slightly bent fork = me freaking out!
Old Aug 3, 2009 | 04:42 PM
DSBoomerRider's Avatar
Default Slightly bent fork = me freaking out!
So the other day I was riding and on a pipe line when I took a turn a bit to hard and stupidly that I dumped the bike a bit harder then usual lol. No big deal, I walk it off, look to see if there's any damage then carry on my way There was no damage at all to the bike except I bent my front break leaver (which is now fixed).
However on the way home I notice that I was steering ever so slightly by a couple of degrees to the right to keep the bike straight. I got home checked everything and everything seemed fine. Handle bars, the mounting brackets, forks, everything is lined up at a stand still and seemed fine but when I start riding I start to compensate to the right to go straight which is barely noticeable.
I heard this is kinda common and that all I did was tweaked the forks in the triple trees a bit and that all I need to do is loosen the forks a bit from the tree clamps and straighten things back up then tighten. Am I on the write track or way off?????
Sorry for the long post!
But please help! I'm going crazy over this
Old Aug 3, 2009 | 04:46 PM
cliffsta's Avatar
Find a pole or a tree, and hit the wheel against the same side you think the front end is crooked (as in, if its twisted to the left, tap the left side of the wheel). It won't take much, and you may go too far with the first hit. My mechanic taught me that trick. He said its a miracle that the forks stay straight while riding; they're barely held straight by the clamps.
Old Aug 3, 2009 | 04:51 PM
Yep like Clifsta said. Remember when you were a kid and your bicycle bars got tweaked and you just put the tire between your legs and twisted it back? Same principle, although you will need to loosen the clamps slightly. Its all good. All of my friends have done it to their bikes. I haven't had it happen to me yet....you know because I'm too good to drop my bike. Oh no he di'int. LOL
Old Aug 3, 2009 | 05:10 PM
punkenduro09's Avatar
and if your bars are stock, they are probally bent. i still find my self bending pro taper 7/8th, hell, mine are bent right now.
Old Aug 3, 2009 | 05:28 PM
God thank's soo much guys. I was almost loosing sleep over this. I thought I was going to have to fork up some coin for a new fork! Man, last night around midnight I brought the bike into my apartment and started jacking it up and taking the front fender off just too see for sure if something was tweaked and sure enough the tire slightly points to the left but barely noticeable to the naked eye
Yeah I hear ya punkenduro09 stock handle bars are junk. I love my Renthal's they are tough as hell. **Knock on wood**
PS: Shaking a fist at are Humble Moderator right now lol
Old Aug 3, 2009 | 05:54 PM
slippery750's Avatar
All of the above! Used to do this with my 80 and 125 all the time. Great advise!
Old Aug 3, 2009 | 10:25 PM
Yea if you bent a fork, I think you would be more concerned about how long you were going to be in intensive care.
Old Aug 3, 2009 | 11:00 PM
LearjetMinako's Avatar
You tweaked the forks, not bent. And here I thought you did what I did when I had my bicycle. Crash into a brick building and bend the forks completely backwards.
Also, helmets really do work.
Old Aug 4, 2009 | 12:37 PM
Yeah I would be lol
Thumps up on head buckets too lol!
Old Aug 4, 2009 | 09:48 PM
skubidoobie's Avatar
I just twisted my forks yesterday on a digger that killed one of my handguards. Came home, put the front tire between my legs, gave it a good yank, and all is well! Good old trick that works well.
