Skid plate 2009 klx250s
I hope you're talking about skidmarks from your bike.
To answer the OP, I have a Scorpion skidplate, and I had a Works Connection prior to that. It would be pretty easy to make on like the WC one...probably the Scorpion one too if you're good a that kind of thing.
Scorpion Skidplate:
Another view
Scorpion Skidplate:
Another view
I made my own out of 1/4 inch aluminum, it's a little dirty in the picture, but it turned out nice. I made it a little taller than the stock plate to cover the portion of the engine casing which was exposed before. It's also waaay stronger than stock. Used basic tools, it took me a while, and no it probably wasn't worth my time, but it killed a few hours
I also added a little plate to cover the water pump over the stock crash bar.
I made one for my "07" Here's the write up https://www.kawasakiforums.com/forum...ication-27266/
The Utah plate is hard to beat for cost, but it is satisfying to make your own stuff. I would have bought one of the Utah plates if I hadn't found a free source for my stock.
Dan
Dan
I also added a little plate to cover the water pump over the stock crash bar.My Utah (Ricochet) plate is hard to beat, for under $90 shipped.
