Shut of while riding. Will not crank until I push the bike around a bit
Old Oct 5, 2018 | 05:26 PM
IKLXG250's Avatar
Default Shut of while riding. Will not crank until I push the bike around a bit
So i was riding home from work and my bike completely shut off on the highway going 70mph. At firdt i thought a co-worker had turned my pea **** to off but that wasnt the case. It would not crank while i was on the shoulder, eventually it started up again just to turn off on me a couple more miles down the road again. When it would idle way it was idling lower than usual and shut off as son as i let off the gas.
Anobody have any suggestions on what my problem could be?
Old Oct 5, 2018 | 06:24 PM
Brewster's Avatar
Clogged gas tank vent??
Ride on
Brewster
Old Oct 5, 2018 | 07:56 PM
Check the carb vent lines. Sometimes they get pinched or melted by exhaust pipe.
Old Oct 5, 2018 | 09:01 PM
dp19's Avatar
If it won't crank you should check for electrical issues, possibly a broken/shorted kill switch.
Old Oct 5, 2018 | 09:58 PM
^ good point.
IKLXG, can you clarify "not crank" please? Does that mean the starter would not turn the motor over? Or does it mean the motor was turning over, but not starting?
Old Oct 5, 2018 | 10:35 PM
durielk's Avatar
Yea, and have you had the bike swimming lately?
Old Oct 6, 2018 | 03:17 PM
IKLXG250's Avatar
Ride on
Brewster
where would I be able to find the gas vent??
Old Oct 6, 2018 | 03:19 PM
IKLXG250's Avatar
Originally Posted by IDRIDR
^ good point.
When it shuts down the display stays on, but starter will not turn over until I rock the bike back and forth quite a bit. When I do get the bike to turn on it idles way lower than normal
Old Oct 6, 2018 | 03:23 PM
IKLXG250's Avatar
carb vent lines look good but I have smelled burned plastic a time or two but couldn’t find where it was coming from. I’ll have to check it out
Old Oct 6, 2018 | 03:24 PM
IKLXG250's Avatar
Never been swimming that I know of. I just purchased the bike second hand 3 months ago with 9,000 miles for $1,100 so I don’t mind fixing a couple of things here and there
