Shift lever rubbing on case
Went on a 160mi ride today and near the end of the ride the shift lever was rubbing on the case so bad that it would get stuck in the "UP" position. Never dropped it, but the PO must have because there were previous marks on the case from the lever.
Do i take it off and bend it out a bit? Are there better aftermarket ones that provide more clearance and are a bit longer?
Yes bend it out ward . There are after market shift levers available from msr I heard the xr650 shift lever splines are the same as are a Yamaha banshee atv lever. Both are longer for bigger feet
No I didn't mean yanking it! Pulling it off n using a vice is sound advise. But im sure a lot of us have experience bending a shifter back into position out on the trail. When a friend broke the shift star and was stuck in second I had to do it with a crescent wrench...
Get a small pipe wrench or use a crescent wrench and use even pressure pivoting at the wrench, bending the shifter without pulling on the shaft. Fit the wrench on the shifter then hold your one hand on the shifter near the back at the bend and push in as you pull out with the wrench. You should end up not putting much force on the shift shaft that way. Your hand at the back of the shifter kind of becomes the bending point. I think you know what I mean.
It's unlikely you'll bend the shift shaft coming out of the case if you're decently careful with how you bend the shifter out. It can also be a good idea to cut a small piece of wood that you can jam in between the frame and shifter where it connects to the shaft. Then you can bend the shifter back in the same plane as the swingarm without much concern of any damage to the shaft. Do not bend the shifter in a twisting motion...like in the same circular motion that the shift shaft turns to shift gears. If you get rough with it in that direction you can bend a shift fork.
