Shaving the head???
Old Aug 20, 2009 | 11:54 PM
dualsportman's Avatar
Default Shaving the head???
Hi there!
I don't what is the exact term in english but to increase power on some engine, we sometime shave the head of the engine to reduce the chamber of combustion increasing the compression.
1. Is that possible on the klx?
2. If yes, can we combine it with a big bore?
3. Another way is to put a convexe piston to reduce the chamber of combustion... is it possible?
Eric the frenchie!!
Old Aug 21, 2009 | 02:31 AM
JasonFMX's Avatar
Holy $hit...shaving my head can increase compression in my bike?! How does that work?
Old Aug 21, 2009 | 03:27 AM
WestOzKLX's Avatar
Not a backyard shed mod, unless your name is Bake.
Stick to what you know and leave the full race mods to those who race and have a factory mechanic. Squish, scavenge, overlap, maximum priming, reciprocating, all words you can Google!
The stock bike already has an 11:1 compression ratio. You'll get a small gain, if any, and I suspect effect reliability for the worse.
That being said. If your name is Tony Scott and can 'blueprint' the entire engine at the same time, then mod away.
Easier and cheaper ways to gain HP without sacrificing reliability.
Old Aug 21, 2009 | 05:18 AM
MaverickAus's Avatar
Pretty much what he said
Old Aug 21, 2009 | 05:41 AM
JasonFMX's Avatar
well, I'm gettin the clippers out. Say goodbye to my hair I guess.
Old Aug 21, 2009 | 05:48 AM
neilaction's Avatar
Cheap mod and fully reversible, over time.
Old Aug 21, 2009 | 06:29 AM
JasonFMX's Avatar
exactly what i was thinking
EDIT:.......for some people it is!!! lol
Old Aug 21, 2009 | 07:12 AM
neilaction's Avatar
Hahaha yes.
Well right now for me, its still a mod. Just
But pretty soon it will be a standard feature.
Old Aug 21, 2009 | 09:34 AM
tremor38's Avatar
Since all I've seen is a chorus of 'don't do it,' I will attempt to at least give you some direct answers. I agree with the responses and reasoning for them, but they all assume you will use the bike as they do.
Yes, it's possible to gain performance on the KLX by increasing the compression ratio though it's not dramtic without it complimenting other mods. I have an artcle in one of my motard rags that shows how they raised the compression ratio of the 249cc jug by milling 0.4mm from the bottom of the jug for a compression ratio increacs of 0.7 (11.8:1 total). That mod alone brought a 2hp gain. It still runs off of pump gas that way, but they added the Yoshimura high cams later-on, which have greater overlap than stock thereby reducing dynamic compression ratio.
The combined effect of all of their mods is pretty amazing though. Free flow exhaust + Twin Air Filter/no lid + low friction RK chain AFAM sprocket lubed with nutech engine oil (bwahahah!!) + Yosh High Cam + the compression ratio bump-up gave them a total increase of over 9hp. Not bad!
With some of the large bore kits, your compression will already be increased to around 12:1 -Kustom Craft and BB 331 immediately come to mind- so I don't subcribe to the alarmist theories out there.
Originally Posted by dualsportman
Hi there!
Eric the frenchie!!
Old Aug 21, 2009 | 12:33 PM
See that web site, they are doing it on harley!!
http://www.nightrider.com/biketech/h...ompression.htm
The winter here in Canada is long! So I have to have a big winter projet to transform my stock 09
That is why i am asking about mill the head, domed piston, and big bore!!
but yeah i want it reliable!
And I have a good friend mecanic
Eric the frenchie
