SF model speed wobble
Old May 31, 2014 | 11:06 PM
RockabillSlapMatt's Avatar
Default SF model speed wobble
My speed wobble occurs around 74-77 mph. The only thing that solves it is getting off the throttle, which I find odd.
The bike never did this before I got my 120/70/17 front avon and my 130/80/17 rear. I'm thinking the rear is too tall or my front tire isn't balanced correctly.
This morning I was doing a long freeway ride with my grandfather-in-law, and I found out that if I lean back and open my legs away from my tank, I get 0 speed wobble even up to 80mph. If I am going 80mph and I close my legs back to my tank, it wobbles like a ****.
Anyone have any experience with this sort of thing?
Old Jun 1, 2014 | 10:11 AM
JoelThailand's Avatar
Tire pressures?
Wheel balancing?
That's an unusual combo: 130 & 120.
I did a spoke check on my bike about 6 months ago (1st time in two years btw) & many of them front & rear were loose!
Old Jun 1, 2014 | 01:12 PM
durielk's Avatar
If your rear tire is larger diameter, it is tilting the bike up in the rear, causing the steering tube to pick up a steeper angle. To get the angle back to stock, you'll need to drop the tubes in the triple, thereby reducing the angle.
Old Jun 1, 2014 | 02:56 PM
My spokes are all tight, I just put some sexy spoke wraps on them , and they were all up to tightness.
I was thinking as well the rear is jacking up the front too much, a 130/80 compared to the original 130/70 is about a 13% difference in height. I'm due for new tires soon, so I'll just deal with it until then. 150/60/17 is closest to stock height with increased width..
130r 120f is a sucky combo, my front is constantly wanting more lean angle in the turns while my rear has 0 chicken strips, and even washing out a few times due to smaller width
Old Jun 1, 2014 | 10:03 PM
RaceGass's Avatar
Preload forks abit more
Old Jun 4, 2014 | 04:26 AM
+1 Preload forks abit more.
I had to experiment with washers after I fitted my new harder springs, as I had a slight speed wobble.
5 pre-load washers in each fork (just less than 0.5inch thick) stainless steel from hardware shop, stopped the wobble in it's tracks!
Old Jun 4, 2014 | 01:05 PM
durielk's Avatar
What is your suspension sag since the preload install?
Basically you raised the front end the same dimension as the increase in tire radius.
Old Jun 4, 2014 | 03:41 PM
JaMan's Avatar
had an avon on a zx-9 cause speed wobble at 120mph every time like clock-work. Tried balancing, suspension setting, everything I could think of to remedy it. Finally wore it out and bought a different tire; no more speed wobble.
motorman224
Classic Sportbikes
Mar 8, 2024 01:05 AM
Power_Man
Sep 12, 2010 12:42 PM
dragGPZ
Classic Sportbikes
May 13, 2009 08:49 PM
biglg7
Feb 9, 2007 06:18 AM
ZX12Rider
Sep 7, 2006 08:39 AM
