setting rear sag
Old 11-29-2014, 06:33 PM
frogandtoad's Avatar
Default setting rear sag
I tried searching, but apparently the search engine doesn't work with three letter words. Is the rear suspension travel 9.1"? What are you setting your sag at...25%-30%? Is there an easy way to adjust the preload...can someone recommend a spanner wrench or should I just use a hammer and punch to turn the nuts? BTW, I have 3.75" of sag now so that's about 41% of total travel if the travel is actually 9.1". I weigh around 180 with gear.
Old 11-29-2014, 06:40 PM
TNC is offline
I see the link to Bruce's Suspension Setup is no longer active. Man...that was the best site for concise, understandable, suspension setup for dirt bikes I had ever seen. It's a shame.
Old 11-29-2014, 07:21 PM
Did you try searching through the FAQs? I bet most of the answers are there.
https://www.kawasakiforums.com/forum...q-links-30733/
Old 11-29-2014, 10:22 PM
Brewster's Avatar
You might want to let us know which bike you have.
The guideline is 1/3 of travel, WITH THE CORRECT SPRING WEIGHT!
Put the bike on a stand when making the adjustments to make it easier to spin the nuts.
Ride on
Brewster
Old 11-30-2014, 01:49 AM
durielk's Avatar
I was under the impression, that different years had different travel, but maybe that is just the front end.
Old 11-30-2014, 03:19 AM
Ride on
Brewster
Oops, it's an '09. Is the spring marked for what rate it is?
Old 11-30-2014, 03:34 AM
ol'klx-er's Avatar
No markings on the spring.
Pretty sure you need a stiffer spring.
Old 11-30-2014, 10:51 AM
klxnoobie's Avatar
According to RaceTech calculator RT - Digital Product Search your good to go with the rear stock rate.
Old 11-30-2014, 12:41 PM
zomby woof's Avatar
Unless you're a serious (fast) rider, the stock rates on the 09 bike should be fine for your weight
Old 11-30-2014, 05:12 PM
outrecording's Avatar
Found this: kb1
I'd save a copy on your hard drive just in case.
Quick Reply: setting rear sag
