Self diagnosis
Old 12-17-2014, 12:42 PM
niro28's Avatar
Default Self diagnosis
Hi guys, i have some problem with this procedure.
When i ground the terminal (wire to "-" clemm) i get this:
But the manual say if there is no service codes - no flash no light
Old 12-18-2014, 02:15 PM
niro28's Avatar
I mean in normal condition there must be a series of long and short blinks of the FI indicator light and service codes can be read...
Old 12-19-2014, 12:23 AM
MaximusPrime's Avatar
Does it run?
Are you saying there is no code associated with a steady flash?
Is your battery going bad?
I don't have FI, but my dash went a little nuts when the battery was on it's way out.
You checked all the fuses?
Everything is plugged in?
Vibrations can take there time to wiggle a connector loose. I did an engine swap once, one wire harness connector wasn't fully seated and about 500 miles later I was on the side of the road scratching my head.
OK, that's all I got...
Paging the fuel injected crowd to the white courtesy phone, please.
Old 12-19-2014, 06:18 AM
niro28's Avatar
Yep, it runs
There is nothing said about steady flash in the manual, it is unnormal...
Does it run?
Warren3000
11-04-2012 12:18 AM
Vanilla
07-23-2009 11:06 PM
neilaction
01-09-2009 02:10 PM
jslamerman
07-17-2007 02:15 AM
vfrpilot
05-30-2007 03:20 PM
Quick Reply: Self diagnosis
