Sealing grease
I used to put waterproof grease on the lips of my filters but dont anymore, just lazyI guess & makes cleaning harder. On bikes like the KLX that have a solid basket to pin the filter against the airbox I have noticed no ill effect from not using it. There are some quads out there that I still use grease on though because they have a crappy filter to airbox seal (Yamaha I am talking to you about the Grizzly, Wolverine, Warrior etc.)
If you are bothering with grease you might as well do around the sealing bolt in the middle of the filter also.
sealing grease? wtf are you talking about..... Sealing the airfilter against the airbox? I hope your not putting grease on the airfilter?!?! Just use air filter oil on the whole thing and it will seal against the airbox....[&:]
Filter oils commonly come with a companion product called "rim grease"... (lol
Yeah, I usually do use it, but I think you're right KLXer... With the filter basket pinning the edge of the foam down, it's really not necessary.
)Yeah, I usually do use it, but I think you're right KLXer... With the filter basket pinning the edge of the foam down, it's really not necessary.
