Safety-Visibility-LIGHTS Show them off
I would be interested in this! Let us know how the install goes and maybe post a vid of it in action? I ordered a replacement bulb for my tail light that has LED's in it. They make 1157 and 1156 replacement bulbs with LED's in them. Alot brighter and less juice to run them. Should be here by the weekend.
Motorcycle LED Brake and Tail Lights - webBikeWorld
I have 8 turn signals, but that's for another post. I am going to pick up one of these bad boys soon.
Mens Master Nylon Mesh Motorcycle Jacket With Ce Armor Neon Yellow Scorpionexo Clearance
I tried some 1156/1157 LEDs on my snowmobiles a couple years ago. They were a big dissappointment. Not near as bright as a regular stock lamp. I DO, however, use the LED peanut lamps in my sled for the speedo/tach indicator lights. You can get the 194-style lamps with 5050 chips on them. That's what I use in the sleds.
If you do go with LEDs, make sure you get the "5050" series. The 5050's consist of a single square chip, with 3 LEDs on the one die. They are super-bright. The standard T3 style LEDs don't come close in light output. I use 5050 LEDs in my automobile "festoon" lamps. I have the 6-chip models (6x 5050 = 18 LEDs). They are white, and very bright.
My roll of reflective tape came this morning. I am going to cut some pieces and apply it to areas that I think will make me more visible.
Front fender, brush guards, side fairing, rear fender edge etc.
Hopefully it does not look like poo when on. I am going to stick to just putting it on plastic as I don't know if the adhesive is strong enough to mess with painted areas. The tape is silver with white lines so its not the YELLOW or ORANGE GLOW stuff.
I will post the pics when complete.
Agreed. I think the daytime brightness/whiteness does make you appear closer. A dim light seems to give the impression of more distance. I will be doing it for sure.
Now more for the night:
A but more reflective tape for the front. The two middle spots are the inside of the radiator cowl. Hidden until the lights it it. The fork locations blend in great so you don't notice them. The hand guards are cut to match the contour and I like it.
Now for side and back.
my HID creates a nice amount of light to grab attention...shows up alot during the daytime is really why I like it.
