Running rich? Or running naked?
Old Nov 20, 2007 | 01:27 AM
2k1w=no$'s Avatar
Default RE: Running rich? Or running naked?
+1 on no pics of mark.
Old Nov 20, 2007 | 01:31 AM
klx250s_rider's Avatar
Deej, I could always come over and do some carb mods for you if you wear a bikini top - then they'll be some talk about me!
Old Nov 20, 2007 | 01:59 AM
kawikathy's Avatar
That would make for an interesting pic in the HOTD!!!
Old Nov 20, 2007 | 03:39 AM
niven's Avatar
Banned
The huge intake of air by the innocent bystanders are obviously detromentally affecting the fuel air ratio of the young lassies bike.
Old Nov 20, 2007 | 03:55 AM
Good call on the filter, Josh. If you haven't cleaned it in a while, Kathy it may just be clogging up a bit from all that desert riding you and Mark have been doing. It that case, it would be going rich since the air flow would be getting more restricted.
Old Nov 20, 2007 | 04:07 AM
niven's Avatar
Banned
backfire on decel, check for exhaust leaks.
Old Nov 20, 2007 | 04:20 AM
ORIGINAL: klx250s_rider
Ewwwwwwwwwwwww + infinity
Old Nov 20, 2007 | 04:31 AM
niven's Avatar
Banned
Clarification, by leak I don't necessaraly mean blowout, a vacuum leak will cause raw cold air to be sucked into the exhaust system and cause a leanburn backfire that can and will blow the after regions clean of off your bike.
Old Nov 20, 2007 | 09:26 AM
ok, whats this about running naked? and i wanna see KK.....
Old Nov 20, 2007 | 03:37 PM
kawikathy's Avatar
It's sooooooo-o easy to get your attention! I have the whole week off so I'll play around with the filter and snorkel and check the plug again. The exhaust doesn't have any leaks, I checked it several times when it was cold, both at the slip-on connection and at the header.
