Rim Locks?
Old Sep 1, 2008 | 12:17 AM
2001KLX300R's Avatar
Default Rim Locks?
I have a KLX300R I recently made street legal and was just wondering if I should take out the rim locks for street riding? Also I just droped my rear sprocket from a 50T to a 47T, it gave me a little more topend but I need a little more what size should i have on the front I think it has a 14T on it now. Any suggestions would be greatfull, Thanks
Old Sep 1, 2008 | 01:20 AM
CousinLarry's Avatar
I put rim locks in, but needed weight to balance. Over 50 was bumpy without it.
Old Sep 1, 2008 | 04:07 PM
KDXmike's Avatar
I'd Keep the rim locks and go to Denniskirk.com and do a search for "spoke weights". Balance that sucka out. I've spun a tire on the rim back in march and it isn't fun being stranded on the road. Like CousinLarry said, the bike's bumpy over 50mph and it gets old really quick. My '07 with a rear rim lock has a ridiculously smooth ride after the weights were added.
Mike
Old Sep 1, 2008 | 05:25 PM
Thanks guyz,
Whats the stock gearing on the KLX250S Front/Rear sprockets?
Old Sep 1, 2008 | 06:27 PM
KDXmike's Avatar
Originally Posted by 2001KLX300R
Thanks guyz,
14 tooth front and 42 tooth rear on an '07.
Good luck
Mike
Old Sep 1, 2008 | 07:40 PM
mudjunkie's Avatar
Question
sorry to interrupt...but speaking of rimlocks, what are the sizes need for a 2006 KLX250?...I have one (used) in my possession, but for the price want to order 2 new ones...getting flats on the trail really sucks!...oh and where can I get spoke weights?
Old Sep 2, 2008 | 11:54 AM
KDXmike's Avatar
The tire sizes on the KLX are the same as a 2006 KDX200. Since the KDX comes stock with rim locks you can get the stock part number for the rim locks at Kawasakipartshouse.com but ordering it from there is expensive.
Front rim lock Part#: 41024-010
Rear rim lock Part#: 41024-009
Front lock is a 1.6 inch. http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
Rear lock is a 2.15 inch http://www.denniskirk.com/jsp/produc...fCatId=&mmyId=
Do a search for spoke weights on denniskirk.com or you can get them from www.dual-star.com
The dennis Kirk spoke weights are nicer as they have a chrome finish while the dual star weights are just lead.
To find out how much weight you'll need to balance the rim lock out, check out this thread.https://www.kawasakiforums.com/forum...light=rim+lock
Mike
Old Sep 2, 2008 | 09:52 PM
KAWASAKIspeed's Avatar
The stock sproket sizes are 14 45 but what i have heard from my dad is that when you put a 15 in the front yeas it can be done but it is snug in there and put either the 45 on or go a couple smaller. good luck. and as for rim locks i dont really notice them on the dirt but that is DIRT so i would not go off of that. i am sure your local shop would not mind putting on some rim weights.
Old Sep 3, 2008 | 07:51 AM
MaverickAus's Avatar
Depends on the type of riding you do, if you never air down the tyres below 18 psi and don't ride steep hills and rocks you will never need rim locks. If you only ride on the road you don't need them.
The KLX250 uses 14/42 sprockets stock and is quite high geared, the 300 has different ratios in the gearbox so it's a little hard to compare. If you can get a 15 tooth front for the 300 (and it fits) it might be worth it, 1 tooth more on the front will make around the same difference as the change from 50 to 47 you did on the rear.
Cheers
Old Sep 3, 2008 | 11:43 PM
So I want to go up on the front?
