Replacement foot pegs
Old Apr 27, 2020 | 05:10 PM
Sse2501996's Avatar
Default Replacement foot pegs
I have a 1996KLX 250 in the foot pegs are worn out I want to replace them with a modern day wider foot peg the stockers are available but are very small. Appreciate any input anybody has
Old Apr 27, 2020 | 09:18 PM
Anything that fits about any KLX250-650 will work on your bike.they all use the same peg.
Old Apr 27, 2020 | 11:31 PM
AussieCheech's Avatar
I picked up a pair recently from ebay.
https://www.ebay.com.au/itm/Foot-Peg...72.m2749.l2649
Old Apr 28, 2020 | 02:15 AM
Sse2501996's Avatar
Hey thanks for the quick reply. I also discovered today that IMS makes replacement pegs for the klx.
Old Apr 28, 2020 | 02:09 PM
Abramsgunner's Avatar
DRC makes a set that falls in between the cheap Chinese $20 cast pegs and the high end $100+ pegs. Somewhere around $50.
I went with the DRC's because I'm rather fluffy at 235lbs and don't trust the $20 cast pegs to hold my porkitude when things get real. YMMV
EDIT: Not that the cast pegs are weak, but the quality control is probably not a priority at $20
Old Apr 28, 2020 | 02:34 PM
Sse2501996's Avatar
Default Klx pegs
[QUOTE=Abramsgunner;549644]DRC makes a set that falls in between the cheap Chinese $20 cast pegs and the high end $100+ pegs. Somewhere around $50.
EDIT: Not that the cast pegs are weak, but the quality control is probably not a priority at $20[/QUOTE
thanks for the info. I appreciate it. I ll check them out.
Old May 2, 2020 | 06:27 PM
azdeuce's Avatar
Got these off Amazon under 50 bucks... comes with springs and extra spikes... come in colors too
Old May 3, 2020 | 02:41 AM
Sse2501996's Avatar
Default Klx pegs
Thanks for responding. I ended up buying some IMS core Enduro pegs that are wider and longer than the stock pegs. The gentleman at IMS was nice enough to tell me that older XR Honda pegs fit on the KLX s.
LaGrasta
Jul 3, 2017 06:14 PM
KLX25O
Nov 4, 2016 03:09 PM
batcave
Jul 27, 2014 11:30 AM
rbarchi
May 9, 2010 08:58 PM
andso77
Sep 7, 2007 03:14 PM
