Rear Wheel spacers
Old Jul 12, 2009 | 11:50 PM
PATCH's Avatar
Default Rear Wheel spacers
Which rear hub spacer/bearing cover goes on which side? Does the wider one go on the drive side?
Thanks in advance
Old Jul 13, 2009 | 01:25 AM
roadglider's Avatar
I don't know what year you have but on the 09's they are marked R and L on the side of the spacer.
Old Jul 13, 2009 | 01:31 AM
PATCH's Avatar
Default 2006
It's a 2006. I tried searching for a picture but the images are no longer available, think I've got it right.
Old Jul 13, 2009 | 01:34 AM
mudjunkie's Avatar
i'd bet the wheel would only fit with them in the right place...otherwise your rotor should rub teh pads and chain be mis-aligned...I am guessing
Old Jul 13, 2009 | 12:12 PM
roadglider's Avatar
mudjunkie is right it will only fit one way. If it doesn't go right together flip it around and try again.
Old Jul 13, 2009 | 12:34 PM
PATCH's Avatar
Default Thx
Thx everyone. I thought it was correct but after reading a thread on a weak rear brake someone had mentioned that might be the cause, guess its time to bleed. Mounted up a Pirelli MT43, tight fit as it is a tall tire, everything rode great.
Skooter
Jul 4, 2009 05:16 PM
solo
Aug 8, 2008 01:26 AM
AciDDreamZ
Ninja ZX-7R
Mar 7, 2007 11:48 PM
DoG
Jun 17, 2006 11:37 PM
konacoiler
May 29, 2006 03:39 AM
