Rear brake fluid reservoir looks empty?
Old Jun 9, 2016 | 06:54 AM
Bigs's Avatar
Default Rear brake fluid reservoir looks empty?
How easy is it meant to be to see the fluid in the rear res'?
I gave Zippy her first oil change today, at less than 300 km, just to get the worst of the running-in crap out. While down there I noticed I can't really see any fluid in that little white box?
I tried putting the bike level, tried shaking from side to side... I just don't see anything?
Is there something I'm unaware of, such as "you have to have the engine running" or "the brakes have to be warmed up" or some such, or did the dealer actually give me a bike with an empty brake reservoir?
The rear brake works, I'm just concerned that I don't see any fluids..? Perhaps too new and clear or something?
Old Jun 9, 2016 | 11:59 AM
MaximusPrime's Avatar
Probably because it's full.
Undo the bolt that holds the reservoir and give it a shake, you'll see the fluid. If not, you now have it where it's easier to add fluid.
If you need to remove the top of the reservoir or the screws that hold the guard in place, use the screwdriver in the tool kit, not a Phillips. All the screws on the bike are JIS, as is the screwdriver. It will remove any screw w/o damaging it, not so with a Phillips.
Old Jun 9, 2016 | 12:04 PM
Bigs's Avatar
Ah... could be, yes.
Regarding the screwdriver thing, I did notice I seemed to be chewing the headlamp adjustment screw a bit. The dealer gave it to me pointing so high that low beam was extra-high beam and high beam was for bird spotting.
That the front wheel wasn't greased and the headlamp not adjusted is what makes me wonder if the dealer bothered checking the brake fluid...
I'll have another look tomorrow in daylight.
Cheers
Old Jun 10, 2016 | 08:00 AM
MaverickAus's Avatar
If you search through the forums you will find there is little grease in the steering head, rear suspension and wheel bearings. All of them need pulling apart and greasing.
Old Jun 11, 2016 | 05:09 PM
Bigs's Avatar
Well I'm going to change the rear sprocket, so whilst at it will get my mechanic to do the rear wheel.
There's a bit of a language barrier but hopefully I'll get him to understand "And them bits there too..."
Cheers
TheDoc46
Jan 25, 2020 09:04 PM
JFlame
Apr 10, 2012 12:16 AM
schneedrache
Ninja 250R
Apr 22, 2008 01:26 PM
iregula
Ninja 500R
Jun 9, 2007 01:13 AM
ntloser
Oct 23, 2006 02:07 PM
