Rear Axle Lube
Old Nov 4, 2006 | 10:34 AM
tremor38's Avatar
Default RE: Rear Axle Lube
ORIGINAL: Marty
Allrighty then, it's time for a quick lesson!
If you take a look at this drawing of your rear hub . . . . .
. . . . you will notice part number 92143A just about in the middle of the screen. This is a sleeve that can be moved around to gain access to the bearing to "knock them out" from the other side. Please note: there is a circlip on one side - please remove the circlip prior to going for a large hammer!
I have a long drive pin that I've worked on a grinder that fits the bearing really nice. You have to drive the bearings out to replace them.
Hope this helps.
Right sized drive pins are handy. Especially if you use a hammer. I have access to a hydraulic press on a local base and have used such things as deep well sockets that are slightly smaller than the outer diameter of the outer race. Don't let the shop attendant see you do that though!
Old Nov 4, 2006 | 02:28 PM
cwgoff's Avatar
My original intention was just to lube up the parts for preventive maintenance. It sounds like the only reason that you would drive out the bearings would be to replace them in the event of a problem. It sounds like the best idea for a PM is just to lube the axle itself and leave the bearings alone.
Chris
cwgoff
Aug 22, 2007 04:06 AM
gas_sippin_Kawi
Ninja 500R
Oct 25, 2006 08:30 PM
evil636
Aug 26, 2006 05:24 AM
2001ninjaZX6R
Jul 20, 2006 07:02 AM
MK1gti20v
Aug 12, 2005 04:49 PM
