Raising the forks
Old Oct 8, 2006 | 12:48 AM
queenpdog's Avatar
Default Raising the forks
Guys,
I have installed Kouba links. Unfortunately, I wish I hadn't gotten the longest ones. Maybe someone wants to trade?
Anyway, I want to raise the forks a bit to balance out the geometry. Anyone know how to do that? I have loosened all the bolts that look like they clamp the forks but they're not budging. Anyone have tips for me?
Old Oct 8, 2006 | 12:53 AM
Bad Bear's Avatar
Default RE: Raising the forks
I just installed the klx4 links 1.5" drop fits perfect now you have to loosen the top bolts and the one on the bottom tree till there to the point you can move them with your fingers. Then just grab them and twist back and fourth just a bit . The fork protector is holding it from moving very far. You can go up about 3/8" of an inch I have 1" risers but have not tried them yet . You can only raise them about 3/4" because theyare tappered at the top.
Happy Trails
Old Oct 8, 2006 | 02:27 AM
Kawi Wawi's Avatar
Yep, the trick is twisting the upper fork tube... Twist and slide, is way easier than just sliding straight up/down...
Twisting won't hurt them, and in fact you should make sure to rotate them so that the bleeder screw on top is easily accessible.
Old Oct 8, 2006 | 08:22 AM
Silver_Otter's Avatar
I have klx4 links. That is the model number of yours?
________
Easy vape prices
Old Oct 8, 2006 | 06:01 PM
queenpdog's Avatar
Yes, I have the KLX4's. The bike might be a little too low now.
Okay, do you guys mean to grab a handful of both fork tubes and push and pull opposite? Or grab one fork tube and attempt to turn it? Either way, they don't seem to be moving. I'll go out and crank on them again after I finish my Weaties. [sm=signs003.gif]
Later: Well, the Weaties must've paid off. Got those forks to move finally. I'll take it for a spin when the rain slows down.
Old Oct 9, 2006 | 02:06 PM
neilaction's Avatar
I'm quite short. 5'4"!!!
Around my friends that's bordering on dwarfism.
And don't they remind me of it!
Anyway I lowered my forks by about half an inch and reduced the rear spring preload a little.
All other suspension settings are set about there mid position.
It works OK.
It's a bit soft but it's worth the trade off as I can touch the ground. Just.
And as a trail bike I'm finding this bike to be almost perfect. For me anyway.
It still means that if I have to stop quickly on uneven ground the chances are I will fall over with only my pride dented.
Cheers
Old Oct 9, 2006 | 05:25 PM
Cowboy 6's Avatar
Hey Neil, I tried to send you a private message but it was returned. Is your email correct on your profile?
Old Oct 10, 2006 | 11:31 AM
MaverickAus's Avatar
Hey Neil, I'm 5' 7" and I had trouble reaching the ground lol, I had the dealer remove some foam so I could touch. Even now it's still a bit high unless I'm using the supermoto rims then it's perfect [8D]
Old Oct 10, 2006 | 06:07 PM
tremor38's Avatar
ORIGINAL: neilaction
It works OK.
Cheers
Don't you mean you raised the forks (IE dropped the clamps an inch)?
Old Oct 10, 2006 | 10:12 PM
Marty's Avatar
How about an alternative to lowering the bike ? ? ?
Would that work?
