quick turn throttle?
Old Dec 29, 2010 | 09:55 PM
  #41
zomby woof's Avatar
Mine is.
A standard 2 stroke mx style tube will be about a 1/5 turn on the KLX
Old Mar 21, 2013 | 10:18 PM
  #42
darkmarc's Avatar
I just resurrected this old thread to say the carb mod works great. I'm using stock throttle cables and tube. I did try it with a single pull cable but the idle position is vague without the return cable. I would say it reduced wot throw to about 80*. I love the reduced twist.
marc
Old Mar 22, 2013 | 03:11 PM
  #43
RimBender's Avatar
1 cable on stock throttle you need to make a stop in the housing. A well place hole drilled and a long rivet protruding into the housing is what I did. Before I installed a magura 314 on my 06 bike.
Old Mar 22, 2013 | 10:10 PM
  #44
darkmarc's Avatar
Is the magura 314 larger diameter at the cable,than stock? If so that should make it even quicker, which I would like. I bent my throttle arm in and drilled the new hole down on the carb, but would still like it so I don't have to reposition my grip.
thanks
marc
Old Mar 23, 2013 | 02:11 AM
  #45
RimBender's Avatar
314 can be changed from 2 positions, enduro or mx, both positions are faster than stock klx.
With ANY bigger diameter your pulling more cable, so the pull is harder than stock. Enduro work fine for me, MX you might wanna unwrap the spring on the carb a turn, though I haven't tried it. I was able to use one of the stock cables no problem, though I switched some nuts around or something.
IMO the quicker throttle is 1/2 the boost guys feel when they go to the pumper, they gain a pump and a better throttle. Why I coined the magura314 the poor mans pumper in another thread somewhere.
Old Apr 1, 2013 | 02:04 AM
  #46
duncanblake's Avatar
I have unwrapped the carb spring and the throttle response really felt like a pumper carb. I've been riding for 40+ yrs. and this was a mod that amazed me. A bit tough to figure out but not impossible. Maybe the best part is my right arm and shoulder don't hurt any more.
Old Apr 1, 2013 | 05:23 PM
  #47
darkmarc's Avatar
Well, I installed the magura 314 on enduro setting with the carb mod as well. I have to say, It's the best mod after destricting and rejet. I can now ride without getting outta shape twisting the throttle, and response is better too.
Poor mans pumper, you nailed it!
thanks
marc
Old Apr 1, 2013 | 06:04 PM
  #48
Savage's Avatar
Could I get some good pics of this? I looked at doing this after reading of it and couldn't get it to clear the brake res.
Old Apr 2, 2013 | 12:32 AM
  #49
darkmarc's Avatar
I trimmed 1/4" off the end of the tube, otherwise straight forward install with no interference with brake master cylinder.
marc
Old Apr 2, 2013 | 12:40 AM
  #50
Savage's Avatar
Pics please.
lukelebras
Jun 17, 2014 02:48 AM
Rosed
Feb 23, 2014 11:38 PM
RockabillSlapMatt
Mar 22, 2013 01:53 PM
Mr.P
Jul 20, 2011 04:06 PM
motoguy128
Nov 13, 2007 09:42 PM
