Quick question for those who have a FMF Q4
Old Jul 26, 2011 | 01:18 PM
rlj's Avatar
rlj
Default Quick question for those who have a FMF Q4
Called Dennis Kirk this morning and was about to order the Q4 and the sales rep had in her notes that the stock rear turn signal needs to be removed and replaced with an after market signal.......I'm guessing due to the length of the pipe. Is this fact or fiction?
Old Jul 26, 2011 | 01:54 PM
rlj's Avatar
rlj
Found my answer on another thread...........sounds like some do and some don't on the 09's.
Old Jul 26, 2011 | 02:19 PM
azdeuce's Avatar
I Melted mine,but for under 20 bucks you can put some aftermarkets on..
Old Jul 26, 2011 | 03:48 PM
buerkletucson's Avatar
I'm doing the same exhaust in the near future.........
Can you give an example of the recommended turn signal replacements that fit without to much hassle?
Thanks.....
Old Jul 26, 2011 | 06:26 PM
azdeuce's Avatar
^^^^ I went to Cycle Gear,they have a big selection,mine are made by Speed Metal,they were 16 bucks,they aren't flush mount but pretty close,they have a stem of about an inch and the blinker is about as big as your thumb,now I said this can't be as bright as stock,but oh yeah just as bright,easy install...done..I waited to see if mine were going to melt,if yours don't they will
Old Jul 26, 2011 | 06:54 PM
sanpedro's Avatar
I'm running the stock turn signals with the Q4, right signal is blackened a bit but not melted and works fine.
Old Jul 26, 2011 | 07:14 PM
KLX'd's Avatar
Default give it some time
I put the Q4 on, worked great, light turned a bit dark, then black. After a few more rides, melted. Then after a few more it fell off, leaving some blackened wires. Got the "edge" replacement.
Old Jul 27, 2011 | 12:36 AM
Here's what I'm thinking of going with.........
I like the idea of going with LED's.
Old Jul 27, 2011 | 02:16 PM
azdeuce's Avatar
^^^ Those will work fine..shorter the stem the better,mine look like that but are more round then arrow,but yeah Get-r-done
Old Jul 27, 2011 | 02:17 PM
BigSky KLX's Avatar
Yes, unfortunately on the 09-10 bikes, it looks like they have that issue.
The pipe works great on the 06-07 bikes. No melted blinkers.
I wish they would come up with a fix for the newer bikes, because it is a really good match for the KLX. Not too loud, not too quiet, it is just right.
