Quick downshift and it stalls
Old Nov 23, 2007 | 01:23 PM
captaintrps's Avatar
Default Quick downshift and it stalls
Has anyone else experienced this? I was riding my bike yesterday for only the second time and more than once I was riding along in 4th or 5th and if I had to lock up everything up and downshift to first, and I didn't let the clutch out right away, it stalled. Like if you're on a fast section of trail and you come up to an obstacle or tight turn and jam on the breaks, downshift and coast for a second or two without revving the throttle at the same time, it stalls out. I also found the front break to be lacking, there are a few trees that agree with me too. :-)
Bob
Old Nov 23, 2007 | 01:33 PM
tremor38's Avatar
Default RE: Quick downshift and it stalls
Are you sure she's not idling a bit slow?
Old Nov 23, 2007 | 01:34 PM
green242's Avatar
Yeah, that happened to me. Once it gets warmed up, it idles lower and lower. When it starts doing that, just turn your idle up just a tad, until it stops doing that.
Old Nov 23, 2007 | 04:36 PM
AgoosSS's Avatar
Has happened to me many times and can be annoying. Typically if your jetting is correct turning up the idle on the KLX cures most of the flame-outs. I noticed I don't have quite as many flame-outs with the pumper carb.
Old Nov 23, 2007 | 04:51 PM
mudjunkie's Avatar
hey green,
was it you that posted about the bike acting like that in the trails, at the first 1/4 throttle? I can't remember. And if so, was turning up the idle the fix for the bike wanting to stall then also?..just curious.
Old Nov 25, 2007 | 02:19 PM
green242's Avatar
Yeah, I think it was me. It was my needle setting. I had it on the 4th slot, and moved it to 2nd and fixed the problems..
I had the problem with the bike stalling after crusing down a road for a while, then I'd let off and begin to gear down and it would just go out, but as soon as I let the clutch out again it was running again of course. I found it to do it when the bike was new, and not so much now.. Or at all.
Old Nov 25, 2007 | 05:00 PM
sinkoman's Avatar
Shouldn't that be happening?
I mean, if you have the bike in first and let out the clutch, isn't it rather expected of the bike to stall?
Old Nov 25, 2007 | 08:28 PM
chris72a's Avatar
Hey Captain,
Just on the front brakes, my first ride they were very spongy but the next ride they were 100% better, maybe there is some glazing or something on the discs when new, once this was gone brakes were fine.
Cheers
Chris.
Old Nov 25, 2007 | 09:11 PM
green242's Avatar
Ummmmm, no sinko.. You're misunderstanding.. Read the thread
Old Nov 26, 2007 | 12:40 AM
gerrynolan's Avatar
+1 on the Idle being low. Just turn it clockwise 1/4 turn at a time & retest it until it stops stalling.
