put my SF on the dyno.
I have a 340 kit, Two bros Fully exhaust, dynojet kit, snork out. Runnign 128 main and needle second clip. 1.75-2 turns on a/f screw.
28.3 WHP and 21 Ft lb. not bad for the little bike. My afr was a little rich like 12.9-13.5 WOT but its definitely acceptable. Especially when its 90 degrees out. Itll be safer for winter months. My cruising afr under 5k was acceptable like 13.5-14 After 5k the ignition switches to more advanced curve so it ran a little leaner until half throttle which was normal. https://www.kawasakiforums.com/forum...pictureid=2165 |
A touch lean, but almost perfect at WOT. Under 12.5 would be a little rich. Ideal is roughly 12.8-13.2, and you're right there.
what kind of dyno was this on? and whats your elevation? those are pretty impressive numbers.
3 Attachment(s)
Do you have any dyno sheets?
I would be interested to see what rpm your motor makes max HP and torque at? Here are a few of my sheets from my dyno run. I have a BB351cc, web 101 cam, ported & polished, FMF powerbomb, 2Bro silencer, BB34mm carb, and kdx snorkle. Attachment 16391 Attachment 16392 Attachment 16393 |
One of these days I want to see dyno runs of one same motor with
- no airbox lid - lid on, no snorkel - KDX snorkel - stock snorkel -- Mikko |
Nice Will, a solid 33 hp, that head work was worth it. :D especially considering it started at 18 hp or so.
Hey, d0gg .... post up your dyno if you can. |
You do know that Stochiometric efficiency of a combustion engine is 14.7:1
Anything less than 14.7:1 is rich, anything more than that is lean Dont believe me, call me a liar then read it for yourself http://en.wikipedia.org/wiki/Air-fuel_ratio |
Originally Posted by buffalony
(Post 424788)
Anything less than 14.7:1 is rich, anything more than that is lean Dont believe me, call me a liar then read it for yourself http://en.wikipedia.org/wiki/Air-fuel_ratio You can run your bike at 14.7, but I won't. Do a search for best power air fuel ratio. Let me know what you find. Looking at those numbers again, he's so close to perfect at WOT, I wouldn't touch the main. |
I agree with what he is saying. 12's are rich... 13.5-14 is about as perfect as your going to get with the additives in the pump gas in the US.
You clearly have no idea what you are talking about.
