Pumper carb pros and benefits
Old Oct 12, 2011 | 07:30 PM
GaryC's Avatar
huh, never had that happen.. Have you opened it up and made sure all was well inside? No gunk? Clean? Spring good?
Had it open many times. no gunk, clean, stock spring. I tried to use the DJ kit spring and it was too light. the slide would hang open everytime i went to WFO throttle so i put back in the stock spring. I checked for burrs on the slide, slide body, etc... I think i just have a bad carb from the get go. It could be why the Previous Owner sold it so cheap with 500 miles on it.
Whatever... I will find out how the pumper works over the next few weeks.
I have 2 dual sport events entered in for the end of this month and first weekend in November. I should have it tuned and get a good idea of it's worth by then. If it sucks, i'll take it off and swap someone for their stocker.
I am a liitle aprehensive about the pumper "HIT" as i really like the smooth power the CV delivers in the real tight stuff. we'll see though soon enough!!!
Old Oct 12, 2011 | 09:22 PM
Arctra's Avatar
Originally Posted by jhoffy22
I did some searching but really found mixed opinions post pumper carb. What can I expect? I hear the term better throttle response being thrown around but my bike already has great throttle response in my opinion.
Mate, take a look at my roundup of my FCR35 carb here: https://www.kawasakiforums.com/forum...e7/#post437777
But coz people are lazy, here we go:
So, what do I think? Overall there is definitely an improvement in the bike and it's rideablility. It has NOT magically created more engine power, but it HAS changed the characteristics quite noticeably. How so? Well, I felt the power delivery is a lot more linear and predictable, and although I expected the AP to cause me some problems with breaking traction on loose surfaces when I snap the throttle, it did not do that once. What the AP did was get the power normally delivered after a second or two with the CV carb down when I wanted it. That change took me a while to get used to - for example, in the tight single track where I would normally hold the bike in 1st gear to keep the revs up I found I could actually ride a lot easier in 2nd gear without having to change down till there were gnarly corners and/or steeper uphills. Being able to stay the gear higher helped quite a lot with fatigue which for a fat bastard like me it a BIG bonus! We had to hop over several logs on the ride, and although I could not lift the front wheel by just snapping the throttle, doing that did lighten the wheel to make it easier to get over the logs - the predictable power delivery helped significantly compared with the CV when it came to log hopping. If I used humps to assist me, I could lift the front wheel pretty easily. This made negotiating braking/rolling bumps easier as I could just lift the wheel a bit and let the rear wheel follow the undulating ground and push me through - great for managing fatigue again
<snip>
So... for those of you considering the FCR35 for your bikes, the burning question is "is it worth it?" This is not an easy question to answer IMO, but I probably went through a bit more pain with my carb than most would thanks to my spigot issues. Here is my opinion:
Is the FCR35 worth it just for the performance increase - NO
Is the FCR35 worth it just for making the engine more predictable and usable - NO
Is the FCR35 easy to fit - NO
Is the FCR35 worth it from the "learning experience" - YES
Is the FCR35 worth fitting for the overall improvement in the engine - YES
If I knew it was going to be as much of a challenge before I bought the carb, would I do it again - I dunno. If I did not have the spigot adapter issues, I would say YES. It ended up costing me more than just getting Bill Blue's Mikuni pumper which should just be plug and play - so I would advise going that route if you aren't up for a challenge and want to save some money. I don't know if the FCR is any better or worse than the Mikuni, so please don't ask. It looks like there is a lot more info and advice out there for the Mikuni, but the info available on the FCR is VERY LIMITED. Hopefully this thread will help people in the future.
So if you can afford Bill's Mikuni which is pre-jetted then I would say go for it, but don't expect THAT big a change. It's one of those changes that leave you wondering whether it has made a difference and was worth it... until you move back to the CV carb and see how much more sluggish the CV is in comparison. That's just my 2c worth though.
Old Oct 13, 2011 | 12:38 AM
buffalony's Avatar
I really have to look into upgrading my suspension. I weigh about 190lbs. How far off of stock suspension am I?
Some where around 30-40lbs over. At 190lbs+gear you need to respring and set your sag. It will help with bottoming out and feeling like you are driving a caddie. In a perfect world where money is free, I would tell you to re-valve. You will see a huge difference in handling, expecially when your hard on the brakes.
Call Moto-Pro, they will hook you up with everything you need. John will even tell you how to set your bike up based on the terrain and style you ride.
Old Oct 13, 2011 | 04:14 AM
New springs made a big difference. Then followed up later with fork valves, which were a huge improvement, especially when going through the whoops or successive bumps. The suspension is too soft for a 190 lb rider unless you're just riding easy.
RaceGass
Aug 5, 2011 09:08 PM
Worlok14
Dec 15, 2008 05:58 PM
markmeinteil
Jul 26, 2007 06:45 AM
eclipsehunter2001
May 3, 2007 06:56 PM
LeftyS7
Jul 22, 2006 10:03 PM
