PSI for SF wheels
Old Aug 10, 2013 | 01:26 AM
mtbcrossover's Avatar
Default PSI for SF wheels
I weigh 160 lbs and am wondering what psi I should be running? Max on the side wall is 42, way to hard. I tried 32 psi and still seems too hard.
Thanks in advance.
Old Aug 10, 2013 | 04:43 AM
JoelThailand's Avatar
This is such a personal thing, it's a tough question to ask or answer.
The crotch rocket guys swear that 35+ psi is best & the hardcore SuperMotard riders like to have 18-25 psi. The low pressure is for quick tire warm up, bump absorption & larger contact patch on the road!
The factors to consider are how do you ride? What do you weigh? What tires have you got...soft/hard....crossply/radial...cheap/expensive....racing/duel sports? Hot country/cold country...winter/summer...hot/cold roads?
When I had the original IRC tires on my bike, I liked 33f & 35r because they we're cheap tires with weak walls & felt really skirmy with lower pressures in them! Now I got a quality set of radials on (Pirelli Diablo Rosso 2), they have a stronger side wall & feel great with 28f & 30r. The roads in Thailand get really hot with the high temperature here & these Pirelli's warm up quick anyway, so I don't feel the need to run really low PSI's.
But I weight 230lbs with super soft performance tires on hot roads.....That's my story!!
It really is a personal preference with many contributory factors! keep us posted if you do any experimenting.
Old Aug 10, 2013 | 03:18 PM
KLXFan250's Avatar
According to KLX250SF owner's manual: front tire 29 psi, rear tire 33 psi
Old Aug 10, 2013 | 05:28 PM
I was running 22 psi for a while and it really smoothed out the bumps which I liked (felt like I had more control in the corners). But I was afraid that this low psi might be making the little 250 a little sluggish. I am going for a rip today and I am going to try 25 psi in the rear.
Thanks for the replies.
Websurfing101
Aug 3, 2012 03:39 AM
benwiggins
Mar 21, 2010 03:08 PM
seximexi
Nov 25, 2008 08:19 PM
USMCsilver
Oct 22, 2008 06:16 PM
EMS_0525
Jun 8, 2006 12:54 PM
