Problems in the water
I have a 2009 klx250s.every time I get in water above the starter my bike stalls. I am not getting I water in the air box and the coil isn't wet. I should be able to run the bike until I go over the snorkel as far as I am concerned but I am still about a foot from that happening. the only thing I can see there that is electrical is the voltage regulator. I also lost the cap on the end of the line to drain the water from the little water collector. once I push it back to shore and wait a couple minutes it starts up and runs like a top, no sputter or hesitation which tells me that I am not taking on water. something is either getting wet or not getting air. please help :confused:
Sounds like you need to do the carb breather mod. :D
(Post 421628)
Here is a nice photo thread from DS. Scroll down and you will see the T-vent mod. https://www.kawasakiforums.com/forum...ead.php?t=8886 |
thanx guys. I have an idea but I will ask your thoughts. do you think runnin those lines into my air box would cause any problems?
When you say "those lines", remember that one of those lines off the "T" should point relatively straight down so gravity will work as it should for this line. The other line can go into your airbox, but I wouldn't worry about spending a lot of time and hassle doing some fancy plumbing to achieve that. Just route it up under the seat to a decently dry looking place that's at least as high as the seat rails.
Originally Posted by TNC
(Post 421652)
I have no carb mods done to mine and haven't had any poblems yet in deep water. However I have had problems with rain and high speed puddle crossings. Read my first post HERE Last half of my post I tell about my problem and cure. ;)
Originally Posted by slippery750
(Post 421682)
+1 its a vacuume operated carb that needs to draw and release air as it works. When water plugs a line it no workey.
I ran mine up under the tank from the "T" so water drains out the bottom, and it still gets a "vent" from the upper line. |
I don't think there's enough "draw" in the airbox to prevent fuel flow, but it's certainly not worth the time/trouble for the plumbing.
so curiosity got the best of me and I decided to start the bike with the lines in water ran for five minutes fine. Then I got the garden hose and started spraying the regulator just to see if I had something shorting out(didn't think that was the problem just did it) the second I hit the plug wire it died instantly. I have just siliconed the whole plug cap and will try again tomorrow. if I can spray it and not stall it I will be of to the pond to see if in fact that was my issue. thanks again.
