Problem???
Old Dec 17, 2007 | 02:19 AM
The frog's Avatar
Default Problem???
I forgot to clean around the spark plug before taking it off. There is a little dirt that went in there... What should I do? Can it damage something? I'm not very common with how engines are made. If there is any dirt that went in, where did it go?
Thanks!
Old Dec 17, 2007 | 02:50 AM
KLXer's Avatar
Default RE: Problem???
Could try sucking it out with something or turn engine over with plug out & see if it comes out.
Old Dec 17, 2007 | 03:12 AM
HeavyFuel's Avatar
ORIGINAL: KLXer
That's a good idea! Fabricate some sort of adapter to a shop vac hose so you can attach a smaller diameter flexible hose, just big enough to fit down into the spark plug hole.
Old Dec 17, 2007 | 04:50 AM
lcpl0331's Avatar
could it? yes. will it? probably not. it will most likely just get blow out with the exhaust when you start the bike. i would try and get it out though. good luck and let us know how you make out.
Old Dec 17, 2007 | 10:01 AM
if the engine is at TDC an adaptor for the shopvac probably wont work.....
Old Dec 17, 2007 | 11:17 AM
tremor38's Avatar
ORIGINAL: EMS_0525
What if it's at TDC of the exhaust stroke?Neener, neener!
Old Dec 17, 2007 | 11:39 AM
LOL..... should have clarified..
Too bad we are all so spread out id like to meet everyone especially you tremor.... id like to see your bike too.... if i was rich i would pay for everyones plane tickets and shipping to have a meet somewhere so everyone was there with thier bikes.....
Old Dec 17, 2007 | 01:13 PM
The frog's Avatar
I'll try the vacuum.
But what does this mean:
What does TDC stand for?
Old Dec 17, 2007 | 01:23 PM
warski's Avatar
TDC = Top Dead Center
Old Dec 17, 2007 | 01:27 PM
i said it wouldnt work because it would create a vacuume in the combustion chamber and no air will come out, if you do that take the plugs out of the side of the motor to turn it over with a ratchet, and open the intake valves a little bit so air can come in from the intake and the shopvac will suck it all out... with all the valves closed it would essentially not move any air in the motor.... stand under? or i could just be thinking about it too much.....
