Please help!
Old Dec 17, 2010 | 06:11 PM
Arctra's Avatar
Originally Posted by PSUdude85
I had a similar problem when installing barkbusters. I put the barkbuster VPS on mine because they had a better angle bend to fit the stock levers, the EGOs will not allow the levers to fit inside the barkbusters. I recon you are running into the same problem.
... the VPS installed with my aftermarket bars (pro taper hi bend), I have since routed the clutch cable on top of the barkbusters for better fit:
If you install the VPS barkbusters I highly recommend you get yourself the triple clamp mounts rather than the clamps that go on your bars. Not only are they stronger (and support the bars a bit in a crash) but it makes the routing of cables much easier.
Old Dec 27, 2010 | 01:51 AM
darkstar1's Avatar
Default figured out uniko mount kit problem
You need to fabricate a bracket that attaches the hand guard to the mounting hardware. The fabricated piece extends your hand guard so it clears your clutch and brake levers. Ask me how and I'll post some pics...
Ninjaattack
Mar 23, 2010 04:44 AM
WestOzKLX
Apr 21, 2008 07:23 PM
fredhill032188
Jul 24, 2007 10:47 PM
STANGRACER85
Apr 25, 2006 04:37 PM
