Oversized fuel tank
Oversized fuel tank
IMS $326 . Cheapo Chinese tank $149. Try to avoid Chinese anything but has anyone tried them?
https://www.ebay.com/itm/38478651082...Bk9SR4qm1cD7YQ
Mine came from Keng Engines in Thailand. Possibly the same item. Fitted it with the 330 kit to cover extra fuel consumption. Havn't done enough hours to rate it long term but no issues with it yet.
fuel level sensor
Is the fuel level sensor a part of the fuel pump assembly? If so, then the level sensor should work with the IMS or Chinese equivalent 2.7 gal tank.
I have the Chinese knockoff on my 2023 KLX300. Fit great doesn’t leak.https://www.ebay.com/itm/275200646564
I installed the new Chinese "2.7gal" tank, loaded the bike on a trailer and went to the nearest gas station to verify the new tank's capacity -- 2.58 gallons. That's about 12 ounces less than 2.7 gallons. I suspect the difference may be due to the volume the fuel pump and filter assembly takes up. Also, the advertised capacity has a caveat that the volume could vary up to 7%. I'm not going to get rid of my Rotopax yet.
Was about 100km road and 70km mountainous enduro.
