Mine came from Keng Engines in Thailand. Possibly the same item. Fitted it with the 330 kit to cover extra fuel consumption. Havn't done enough hours to rate it long term but no issues with it yet.
Is the fuel level sensor a part of the fuel pump assembly? If so, then the level sensor should work with the IMS or Chinese equivalent 2.7 gal tank.
Thanks Olderider, I bit the bullet and placed an order for the larger tank, especially after learning that the low level fuel light sender is integral with the fuel pump.
I installed the new Chinese "2.7gal" tank, loaded the bike on a trailer and went to the nearest gas station to verify the new tank's capacity -- 2.58 gallons. That's about 12 ounces less than 2.7 gallons. I suspect the difference may be due to the volume the fuel pump and filter assembly takes up. Also, the advertised capacity has a caveat that the volume could vary up to 7%. I'm not going to get rid of my Rotopax yet.
I got about 170km out of mine on the weekend before fuel light came on. So still some in the tank. Given its a 330 with the bigger injector I will not complain 👌
