Opening up the KLX250S
Old Jul 30, 2009 | 08:19 PM
  #81
slippery750's Avatar
Take out the slide from the carb' (only requires you to remove the side panels and the tank and the carb' top,) and measure the vent hole. If a 7/64" bit wont slide through the vent, then drill it out so it will.
Thanks, I'll check it out right now.
Old Jul 31, 2009 | 09:04 AM
  #82
You must be talking about the hole next to the needle hole on the bottom of the slide... Can you go bigger than 7/64" or will it hinder performance?
Old Jul 31, 2009 | 10:32 AM
  #83
WestOzKLX's Avatar
That's the one.
7/64" is the recognized benchmark. Going bigger will have adverse effects, slide hover etc. You can get problems erratic idle. Mine is 7/64" and it idles great. Has great response too, for a CV type carb'.
Old Jul 31, 2009 | 04:08 PM
  #84
Ok thanks, its drilled out but since I had the bike apart I took the screen out of the air box too so not too sure how much of a difference the drill did but the both of them sure made an improvement! Bike is running a little lean so now I get to change out the main jet.
Thanks again WestOzKLX.
Old Oct 18, 2010 | 10:40 PM
  #85
09klx's Avatar
Originally Posted by cosmickites
can you pleaes give me more info on this? i have removed teh snorkel from the airbox, is this the same thing in a sence? sorry about my ignoarance, just dont want to F someting up.
any pics would be apprecited or must a marked up diagram. thanks
2) Drilled the crankcase vent hole at the lower front right hand corner of the airbox out to 3/8". Like the KLX300, this system is plugged up and enlarging the hole helps move air out of the crankcase. It also means oil has a clear shot at your airbox if you lay the bike over.
How does this help with performance?
Old Oct 22, 2010 | 01:07 AM
  #86
texengland's Avatar
If I drill out the stock pipe and put some holes in the Airbox cover will I have to mess with carb? I plane on getting a new exhaust and jet kit later on, but I just don't have the funds right now and we are hitting the trails on Saturday.
Old Oct 22, 2010 | 02:47 AM
  #87
FM_Thumper's Avatar
No point in doing that without jetting as the bike runs lean as is stock.
Wow this thread brings back memories of when I first my KLX. I wonder how bmwhd is doing? That guy knew his stuff!
Old Oct 22, 2010 | 03:06 AM
  #88
texengland's Avatar
Sounds good I'll just run it bone stock on Saturday then. Thanks
Old Oct 23, 2010 | 01:19 AM
  #89
tremor38's Avatar
He pops into the FJR and KLX threads at Adv Rider every now and again. Seems like he's doing fine.
Old Oct 28, 2010 | 01:46 AM
  #90
choogyddad's Avatar
I have just finished putting the Jet Kit, FMF Q4 and KDX snorkel on my bike. It's like a night and day difference. I am debating changing to the 13T countershaft sprocket, but I'm afraid it will make the bike a little squirrely offroad. Anyone have any thoughts?
