Okay - A Quick Tutorial is in Order
Old May 10, 2006 | 02:24 AM
Marty's Avatar
Default Okay - A Quick Tutorial is in Order
On the suspension settings, both front and rear.
Compression dampening on front fork: higher number of 'clicks' out for lighter, less for heavier rider?
Compression dampening on rear shock: higher number of 'clicks' out for lighter, less for heavier rider?
Rebound dampening on rear shock: higher number of 'clicks' out for lighter, less for heavier rider?
I see that Todd has his set for '4' and others have them for a higher number.
On other bikes, these adjustments can make a huge difference.
Front forks - what is the oil level supposed to be set at? Might be another thing I do on the bike. Set the oil level a bit higher to stiffen up the front just a tad.
Old May 10, 2006 | 03:35 AM
okiswede81's Avatar
Default RE: Okay - A Quick Tutorial is in Order
ORIGINAL: Marty
I think you have it right on the compression on the forks and shock. Not too sure on the rebound but from what I have read I think you have that right also.
I have heard that we have 5w fork oil in our forks, maybe going to 10w will help stiffen them up (Anybody please correct me if I am wrong). I also remember tony saying that he changed the oil in his forks and shock to hondaline fork oil and this supposidly helped his out quite a bit. But, I do not remember what wt he used.
Old May 10, 2006 | 11:08 PM
greenweenie's Avatar
I was adjusting the front/rear shocks on my predator a few weeks back, and it was all the way clockwise I believe was the stiffest and then bring it back counterclockwise as many number of clicks as needed. I am guessing it is the same way without looking in the klx manual.
Old May 10, 2006 | 11:54 PM
onestarr99's Avatar
Turn in Clockwise = stiffer
Turn out, Counter clockwise = softer
8 clicks out from fully seated is suppose to be stock setting.
Old May 11, 2006 | 12:10 AM
Marty's Avatar
So, if one set the compression dampening for a 4 and the rebound for a 12 they would have a suspension that was stiff to compress, but recovered quickly?
Klxrelic
May 14, 2012 06:24 AM
je2000
Apr 14, 2009 08:26 AM
je2000
Aug 28, 2008 05:57 AM
Notstock
May 28, 2008 01:12 PM
Marty
Jan 21, 2006 02:32 AM
