Is this oil OK to use in my '09 KLX250??
Old May 18, 2011 | 01:32 PM
zomby woof's Avatar
People try to make it more trivial than it actually is.
No, people try to make it more complicated than it actually is.
Old May 19, 2011 | 01:28 AM
09'Kawi250s's Avatar
i tried that actevo crap and my tranny started shifting hard. so i went back to crappy honda 10-40 and im at 15,000 miles.
Old May 19, 2011 | 01:56 AM
FWIW Castrol Actevo is what Bill Blue uses in his klx's. I asked him what oil he recomended in the 351's He wasn't against using other oils, that's just what he uses.
Old May 19, 2011 | 04:06 AM
2007 Green Machine's Avatar
Just use what the manual says and be done with it.
Old May 19, 2011 | 11:15 AM
maninthesea's Avatar
But manuals are just mfr's opinions
Old May 19, 2011 | 02:22 PM
Here's a little flow chart I whipped up so you can determine if the oil is good to use in your bike. Please excuse the crudeness of my model, I didn't have time to build it to scale.
It's as simple as that. People try to make it more trivial than it actually is.
Dude Larry! That is awesome!!! Looks like the dichotomous key I use to repair the furnaces up here at work. Good stuff man....and probably true.
Old May 20, 2011 | 03:53 AM
Your right, but you can NEVER go wrong with using what the manual says. Any company does countless hours of testing on oils for engines they produce and under normal conditions it tells you what to use.
Old May 20, 2011 | 01:05 PM
I know I was just supplying the answer any man should have ready to deploy in retort to "why dont you read the instructions" fired at him by his significant other.
Cheers, Jim
Old May 21, 2011 | 04:11 AM
Cheers, Jim
Been there many times myself, and my girlfriend always says didn't you learn your lesson last time you didn't read the instuctions!
Old May 21, 2011 | 02:25 PM
Blackheart58's Avatar
Ever since Castrol's winning lawsuit against Mobil 1 regarding using the term "synthetic" to describe severely hydrocracked Group III oil, it has changed the term from a scientific term to a marketing term. MOST "synthetics" are not truly man-made molecules anymore. They are simply highly refined Petroleum. Don't wring your hands about that, though, because Group III oils perform within a gnat's eyelash of true man-made base molecules, at a fraction of the price. Don't worry about mixing anymore...unless you have some 20+ year old TRULY synthetic oil laying around...in which case I'd donate it to the local oil collection tank.
Also, you don't have to worry about friction modifiers hurting your wet clutch plates if you use a 15w-40, 15w-50, or 20w-50. Unless someone can point out an exception, I've NEVER seen any of these oils with an "Energy Conserving" label...that label denotes some friction modifier additives that could potentially mess with the clutch pack...ALTHOUGH, I've known many people that have used Energy Conserving oils in wet clutches, and they didn't have problems. I'd avoid them, though...they tend to be too thin for most motorcycle uses anyway.
