Not the KLX but need help
Old Sep 23, 2010 | 10:43 PM
David R's Avatar
Too much thinkin
I would replace the piagtail (plug),bulb and battery, check the charging voltage and ride the bike.
David
Old Sep 24, 2010 | 12:19 AM
maninthesea's Avatar
Originally Posted by GreenMonsta
When Voltage decreases the draw (amps) increase and could easily melt the wire.
Like some of the others stated this does not applyhere. Where it does apply is to situations with motors and many IC chips.
& Like the others have said bloated battery is often a symptom of overcharging from bad voltage regulator.
So definatly change the battery and plug and then moniter the voltage with the bike running.
Cheers Jim
Old Sep 24, 2010 | 04:21 AM
redpillar's Avatar
There may have been a short cct at the headlight connector (burned connector). This would cause a serious current draw which would prevent the starter from functioning properly (bike souldn't start), heating the battery to the point of failure (swollen battery). You would think though, that a fuse would have opened.
Perhaps pinched wires in the headlight area?
buerkletucson
Oct 13, 2011 05:30 PM
Borischan
Sep 19, 2010 10:29 PM
Rusty FJ
Dec 16, 2006 01:15 AM
Bonafide
Apr 27, 2006 03:06 AM
madgreek
Ninja ZX-9R
Jan 10, 2006 09:53 PM
