no-start
Old Dec 23, 2007 | 05:52 PM
MADDOG2007's Avatar
Default no-start
HeyheyheyKLXers
Moist as the amazon round ere rihgt now. bout 35 degrees f.
Turns over good,Ran good when I parked it. I suspect the coating of moisture is the cause. Any one else have this problem?
Noticed in last two heavy rains she wanted to stall if the revs dropped.Coil grounding or ignition switch shorting?
Or...
Sogg(y)estions or hints
Merry Christmass everyon!
Maddog(Marc)
Old Dec 23, 2007 | 06:07 PM
HeavyFuel's Avatar
Default RE: no-start
Carburetor icing?
http://en.wikipedia.org/wiki/Carburetor_icing
Carb icing occurs when there is humid air, and the temperature drop in the venturi causes the water vapour to freeze. The ice will form on the surfaces of the carburetor throat, further restricting it. This may increase the venturi effect initially, but eventually restricts airflow, perhaps even causing a complete blockage of the carburetor. Icing may also cause jamming of the mechanical parts of the carburetor, such as the throttle butterfly valve.
Old Dec 23, 2007 | 06:31 PM
gerrynolan's Avatar
ORIGINAL: HeavyFuel
Carburetor icing?
Carb Icing usually doesn't cause a no start. It happens while riding. But... if it was Iced when it was parked, maybe. I would try a hair dryer aimed at the Carby for a few minutes & see if she starts. If not then it's backto basics. Spark + Fuel + compression = Combustion. Which one is missing???? My gut feeling is a fouled spark plug from the last ride or even a plug that's spent. Good Luck & let us know how you make out
Old Dec 23, 2007 | 06:45 PM
HeavyFuel's Avatar
Ooops. My bad, I should have read more carefully. How about pulling the spark plug out and shoot a tiny squirt of starting fluid in the bore and shoot a bit on the spark plug to dry it off?
Old Dec 23, 2007 | 06:50 PM
HeavyFuel's Avatar
This reminds me of a guy at work who has an '86 Ninja 600. He doesn't ride it much, he tells me he heats up the exhaust headers with a propane torch and it fires up. Sounds kinda nutty to me, but this guy is a mechanical engineer and a sprint car racer, so he might be on to something, but I'm not sure what. Maybe the heat transfers to the head and helps keep the plug from fouling? I dunno...
Old Jan 26, 2008 | 07:01 PM
MADDOG2007's Avatar
No winter riding??
I'm ^#@^%%$(* off!!
Thanks 4 the replies.
Am I the only one?
Started fine when above freezing last week.
Old Jan 26, 2008 | 07:15 PM
MADDOG2007's Avatar
Yo ...
Anyone have an easy spark plug removal methood?
Marc
Old Jan 26, 2008 | 07:22 PM
warski's Avatar
ORIGINAL: MADDOG2007
No winter riding??
I'm ^#@^%%$(* off!!
Am I the only one?
I don't think you have to worry about the temperature, it was 22 degrees when I rode mine to work yesterday. It started with one push of the button...
Old Jan 27, 2008 | 02:15 AM
tremor38's Avatar
1. Close petcock
2. Drain carb bowl
3. Close drain
4. Open petcock
5. Start engine and ride, ride, ride.
Old Jan 27, 2008 | 02:34 AM
Carp824's Avatar
I had the same problem when it was below 40 degrees and I pulled the bike into the garage and placed a small space heater near the engine to warm it up. Waited about ten minutes and then it cranked right up. Seems to be cold natured. Not nearly as bad as my Honda XR400. I kicked it about 100 times today before it would start.
