No ifs, ands or butts about it.....
Like Deej I just stand on the pegs a lot.
I get sore from sitting for long periods of time, period, doesn't mater how comfy the seat is. The nice thing about the KLX style of bike is that you can ride standing up comfortably. Having ridden other types of street bikes that have super comfortable seats, but don't allow you to ride standing up comfortably, I can attest that being able to stand up, or even do squats while riding, allows me to ride for longer periods of time and not get a sore back or butt.
I do a fair bit of mountain biking too, not much to the seats on those things. If I forced myself to sit the whole time I was riding on my mountain bike I'd be a cripple by the time I got off. (and probably impotent too)
If you are still getting a sore butt after adding all that padding, try just standing more frequently while you ride.
The Suzuki DR650 undoubtedly has the worst stock seat ever built...and I found the Seat Concepts offering to be only a minor improvement.
Then I found out about these: Sweet Cheeks | Cycle Analyst
Thanks
I wanted to use carpet backing foam rubber for the layering of new padding but Home Depot only sells it in big rolls. So instead I used -- you may not believe this -- high density bubble wrap. Not the kind you can pop with your fingers (although that might have worked, too) but a much more sturdy kind.
It's firmer than the OEM foam which was removed, but having had rock-hard Corbin seats on several bikes in the past I think firm is OK if the weight is distributed enough.
We'll see. The nice thing about DIY seat mods is that you can keep experimenting until 1) you get it right; or 2) you give up and order a Seat Concepts kit.
The first steps involve making the seat wider and then (I talked to a local upholstery shop) adding strips along the side of the OEM cover so that it can be re-stapled.
If you are going to involve an upholstery shop you might as well have them make up an entirely new cover.
