No fire
I was installing vapor on m 07 klx250s and grounded brown wire and it sparked and burn 20amp main fuse and now I have no fire, after replacing fuse. Traced brown wire back to ignitor and it has power but no power at coil blue wire. How do I check or is there a way to check coil and or ignitor?
Went and got resistor today since they were $1.50 and that does not seem to be the problem. Can make the coil fire with a hot wire so I would think it is ok.
