New Muzzy and 45t question
I just ordered new muzzy full system.Cant wait to get it on.Now I want to change sprocket size. Does anyone just have a 45t on rear and what will it do without changing sprocket up front.
RE: New Muzzy and 45t question
I'm waiting for mine to come in the mail (45T) and as soon as it does I will post a review about it.
My bike is in stock form as far as performance goes. So this will be a 14/45 tooth set-up with a new X ring chain and some Trakmasters:)!!!! Dave |
Buy a 13t front sprocket and keep the stock rear. You will save money and you willput the rpm range into the meat of the torque. I have this set up with the free mods and I weight about 265, and I can run all day at seventy miles and hour with no problems. And it will pull a wheelie in 1st and second gear. Duane 5157
Yes I run the stock 14t up front and a renthal 45t rear, its alot better imo. Only drawback is you need to buy a longer chain, whereas the 13t up front allows you to use the stock chain. I opted to keep the 14t up front because it has a vibration dampner on it and the replacements dont...some have complained and thenmost say they dont notice a difference without the dampner.
I was under the impression that either going one down in the front or 3 up in the back was the same thing performance wise. Since I've also heard that the stock chain was so-so, replacing it was a no-brainer along with the sprocket, plus it all has to come off for the new tires anyway.
That's why I went with a rear 45T. I've also heard the front 13T is louder than stock without the dampner and it will wear faster than a stock 14T. Allthings considered, for me, the 45T was the way to go.................. Dave |
ORIGINAL: double d6 I was under the impression that either going one down in the front or 3 up in the back was the same thing performance wise. Since I've also heard that the stock chain was so-so, replacing it was a no-brainer along with the sprocket, plus it all has to come off for the new tires anyway. That's why I went with a rear 45T. I've also heard the front 13T is louder than stock without the dampner and it will wear faster than a stock 14T. Allthings considered, for me, the 45T was the way to go.................. Dave Iam running 14/45 and really like the change! |
honestly, switching to the 13 toother up front, besides the pipe, was the most dramatic increase in performance. it's only a $12 mod. buying a larger rear sprocket is really meaningless unless you go up at least 3 teeth, and you have to buy a new longer chain. i eventually went 45 in the rear with the 13 up front and this is the best ratio imofor the bike because it puts it into the meat of the power quicker and gives you more low end. the 13 tooth is not noisy and mine doesn't show signs of any wear. if you want to spend unnecessary moneygo ahead, but if you want a cheap, easy, immedately effective mod, then the13 tooth with stock rear and chain is the way to go.
ORIGINAL: Iowaguy i eventually went 45 in the rear with the 13 up front and this is the best ratio imofor the bike because it puts it into the meat of the power quicker and gives you more low end. buying a larger rear sprocket is really meaningless unless you go up at least 3 teeth if you want to spend unnecessary moneygo ahead, but if you want a cheap, easy, immedately effective mod, then the13 tooth with stock rear and chain is the way to go. Sorry if I sound harsh, but I spent alot of time researching this from some sound advice from this board. Ifinally took the plunge and spent over$300.. and to hear that all this was unnecessary and meaningless just rubs me the wrong way I guess.[:@] So take no offense from my post, but use it as constructive criticism....ok??? |
That was the first mod I did was the 13 tooth. And while it made a difference, I decided that when the shop did the jetting and the full muzzy I might as well have them put on the 45 tooth on the bike. I think its perfect. I can still do 60-65 comfortably and on the trails it has that low end grunt we all love. GIT-R-DONE!
Did I just say GIT-R-Done?.......Lord I apologize...and be with the starving pygmies down in New Guinea..amen.:D:D:D I guess its just one of those goofy days where the caffeine has taken over and I am just trying to hold on.[8D]
